98 V70 trailer Topic is solved
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
UPDATE
Youtube links:
Teardown part 5
P80 manual shifter cable 1
P80 manual shifter cable 2
V70 engine drop sneak peek :D
I forgot to disconnect the brake lines and fuel line. WOW how durable they are!!! See below.
As you can see, I managed to remove the spaceship ONLY by bending it upward before spinning it.
I had already loosened the 12mm nut on steering rack to drop it out. I thought that was all that was required. OH BOY I tried dropping it out and that one bolt held the entire weight of the subframe. WOW THATS A STRONG BOLT!!! But turned out the paired bolt had to be removed completely.
On the head, I noticed a difference in the carbon build up on the intake valves. The three on the passenger side and farthest driver side were all fairly similar. But second from driver side was kinda oily. Im assuming that was a cause of the misfire it had? However one of the far driver side valves had a strange gray crusty on it. Strange.
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1611 times
Been thanked: 4071 times
Save the spaceship and that steering coupler. Those aren’t available new any more
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1076 times
Post by volvolugnut »
Be very careful using cement blocks to support things like cars and engines. Results like shown in your photos - broken. High risk of personal injury. Best to use wood blocks or jacks.
CIK7
Post by CIK7 »
abscate wrote: 14 Sep 2025, 15:09 Save the spaceship and that steering coupler. Those aren’t available new any more
Ive saved the spaceship. But Ill figure out how to get the steering knuckle off. Are you refering to the steering rack or pinion? is it the thing I posted a pic of?
CIK7
Post by CIK7 »
UPDATE
Youtube link
I have a few pics of some damage on the transmission (flex?) plate and inside the bell housing.
Nothing to worry about on that flywheel and clutch pressure plate
See pic for thing to save! You want all the hardware too, the funny butterfly bolt at the top is also NLA
The coupler should come off the rack ok after your remove that pinch bolt , soak it in liquid wrench or PBB for a day, then gently tap it up to come off.
Can you send it to me for $50 plus shipping?
CIK7
Post by CIK7 »
abscate wrote: 15 Sep 2025, 03:16 Nothing to worry about on that flywheel and clutch pressure plate
So the housing and pressure plate are totally fine?
Yes will do. Will remove then get shipping info. I only have Paypal btw.
Also do you want the spaceship? I slightly bent the elbow in order to remove from manifold but can easily be bent back into place.
rudsaki
Year and Model: 1998 S70 T5
Has thanked: 29 times
Been thanked: 16 times
Post by rudsaki »
CIK7 wrote: 02 Sep 2025, 15:37 Another idea...
After welding on the new front wall, I could design the structure inside to install a plexi window.
For an old truck camper shell back window I went with Polycarbonate (Lexan). It might fine scratch more than plexiglass, but is much stronger.
Also my dear departed Pappy would have liked your fuel line from trailer idea. When we were kids dad pulled a 15' foot trailer with our 1964 Volvo 122 wagon. It would overheat on grades so he tapped into the trailer fresh water tank with a rubber hose and electric pump with spray nozzles he mounted in front of the radiator!
Previous Volvos
1969 142s Blue manual.
1966 122s Yellow with the 69 motor in it
1971 144s Red . Also the '69's motor
1973 P1800ES Aqua Manual with OD.
1971 142E Light Blue manual with OD.
1979 244DL Brown manual. Marriage/baby car. Divorce, Ex got it and sold it to my father!
1968 1800s White manual/OD. Strong runner. Killed by a '66 T-Bird
1984 242 Turbo Intercooler Silver Manual/OD
1966 1800s White Manual/OD
1985 740 Turbo Intercooler Silver Manual/OD Sold to Nephew
CIK7
Post by CIK7 »
rudsaki wrote: 15 Sep 2025, 18:47
That is really cool.
Because of the safety issue, of a possible combustion upon accident, I am likely going to exclude a linked hose and instead at most only use it for siphoning.
I am looking at Duco acrylic on Amazon...
https://a.co/d/9DHpMi6
Or something similar...
https://a.co/d/6cnlpGc
CIK7
Post by CIK7 »
Abscate, I'm pmed you. The message is staying in the outbox and it has not completely sent. I don't know why. Checking that this is all you wanted. I saved the spaceship. Do you want that too? Please PM me the address to mail it. I'll send my PayPal email once you pm me.
