Remove the rear axle? You mean like this?
1998 v70 is it possible to remove rear axles permanently ?
bronco
- Year and Model: 1998 V70
- Has thanked: 49 times
- Been thanked: 24 times
So far so good on the stub axles . I got out on the highway and all the weird moaning noises are gone. They were rotational noises I assumed coming from the wheel bearings and are no longer present.
Now whether rear CV axles and or the differential axle bearings were contributing I have no idea. I cant really look at them unless I take the diff out.
I put S70 shocks on in place of the nivomats. I did not buy Tbars I just pushed the sleeves and bushings out of the new shocks and pressed the tbars I had already in . I had some urethane bronco track bar bushings laying about and just clamped them in a vice and took a wood rasp to the outer diameter until they would fit in the eyelet.
I'm sure as several have said I have lost spring capacity but considering both of my nivomats were defective I can't tell any difference . It handles much better because it has functioning shock absorbers now and I think not spinning all that rear axle stuff i'll probably pick up a little mileage.
I probably deleted 50 pounds of weight from the rear between the axles and nivomats that might be helping a little.
Of course I never haul anything with the car so if I put weight in it then not changing springs would be a more obvious issue. I'll drive another week or so then jack it up and take a look for loose bolts or other issues.
I'm going to start searching for parts to do a FWD swap in the next few months but maybe i'll find some backing plates first
Excellent. I’ve cancelled my trip to Boston with my dolly…..
Somewhere from my travels in Russia years ago I have a picture of a car going down the road ona piece of wood for a wheel
- 11 Replies
- 834 Views
Last post by bronco
- 1181 Views
Last post by rmmagow
- 537 Views
Last post by ChrisVince
- 361 Views
Last post by jonesg
- 12 Replies
- 2913 Views
