Hello!
I have bought a Chinese dice to erase an airbag code because bad connection under the passenger seat, but my vida doesn’t communicate with the SRs module… it communicates with everything else? Any ideas why?
I have vida 2014d installed
Volvo s70 2000
Best regards Joel
No Communication with srs on vida, s70 2000
- Has thanked: 2857 times
- Been thanked: 1332 times
Hello Joel and welcome to MVS. It might be your DiCE clone. viewtopic.php?p=451283&hilit=dice+commu ... le#p451283 In that thread the user has a similar situation.
Because you bought that unit I would suspect you don't know anyone near you with a DiCE unit so that you can try theirs and thus do an A/B test between the two...
- Has thanked: 2203 times
Or pay a dealer for an hours diagnostic and a reset. That way you should find out if your car has another issue or if it is your Dice clone. Strangely, I have issues with my 10+ year old Dice clone recently not connecting to some cars and being fine with others. It will just not connect with some cars at all. I also have had issues with my newer laptop with the Boot & Go external SSD with Chrome and Win10. I have yet to confirm if the issue it the newer 2014D. I have not had the opportunity to try the older laptop with Win7 Pro, IE9 and Vida 2014A.
I could not get the newer system to connect to the C30 challenge initially at all, then after some electrical clean up it would work but not allow me to do live data scanning.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Probably sounds crazy but worth a try: turn the ignition key to position I and then back off ten times at a normal speed then see if it connects to the SRS.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
I have an iCarSoft V2.0 scanner.
On my kids 2002 S60 it has a failed SRS module. Code was something like ‘internal fault’, requiring replacement. eBay replacement I got was configured for a V70, not S60, so wouldn’t work for me.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
pfmet
- Year and Model: V70 1999
- Has thanked: 45 times
- Been thanked: 22 times
I don’t know if this changed by 2000, but I had the same issue with my 99 three years ago. I bought the VIDA laptop with Mongoose JLR cable from Diagnostic Laptops. Swore it would read, diagnose, and reset the SRS module/light. It would not. When I’d click on anything to do with SRS it would display a dialog box with something like “no comm with SRS module”. I posted here about it, got some suggestions and empathy and finally someone posted back that the 99’s DO NOT communicate with SRS module on VIDA. Just recently a long time Volvo mechanic and new friend of mine confirmed that the 99’s will only communicate with modules in front of the DIM. That leaves out the SRS module and numerous others. I finally bought an Autel MD 806(?). Which read and reset the SRS module after fiddling with the infamous pink and green connectors under the seats. And all was good.
If you study the 99 v70 wiring diagram, the schematic of the SRS module shows no CAN connection. I’d noted that early on but took a while to understand the lack of comm to the DIM where the VIDA ties into the CAN bus I guess.
- 9069 Views
Last post by spue
- 27 Replies
- 28303 Views
Last post by cn90
- 1089 Views
Last post by BEJinFbk
- 2177 Views
Last post by RickHaleParker
- 5204 Views
Last post by plarose
