What are the recommended timing belt/tensioner changes - Mileage/Years?
I did not change the hydraulic tensioner last time as it had no leaks and tested ok. The tensioner as far as I know is the original and has now done 260,000 miles. Should I not bother to test it next belt change and fit a new one or would you test and if ok, go again?
Timing belt/hydraulic tension change - 1996 N/A 850 Est.
- Has thanked: 2199 times
I know cars with similar mileages with the original hydraulic tensioner still in use. However, my opinion is if you plan to keep the car, on the next timing belt change I would consider changing it for no other reason than the age and it has oil seals that will fail. The cost of the new part v's the cost of a bricked engine is no comparison. My other recommendation is to use the OE Volvo part or if anyone knows who the OEM supplier is use their part.
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I believe that Aisin is the OEM for the tensioner.
1999 V70 GLT
1999 V70 GLT
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Good question. I was just looking at timing parts from my 96 last night. I replaced everything about 2 years ago, and the parts I removed (pulleys, tensioner and water pump) look and feel fine. I'm debating on whether or not I should scrap them. I think they have about 90K miles on them.... odometer didn't work at the time, and I hadn't gotten an OBD2 reader yet, so I'm unsure of the mileage when I did the belt.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
aeg
- Year and Model: 97 850GLT
- Has thanked: 2 times
- Been thanked: 46 times
There was a thread recently with info from Abscate about changes to the recommended interval by model year. These are my summary notes:
I think it's a good idea to change the tensioner and both pulleys with every timing belt change. Some people suggest replacing the water pump once every two timing belt changes.
Code: Select all
'93 50k
'94-'97 7 year / 70k
'98 (hydraulic tensioner) 7 year / 70k
'98 (mechanical tensioner, engine 1266196+) 10 year / 105k
'99- 10 year / 105k- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I have been following aeg's practice above, and change both pulleys and the tensioner with each belt change. I replace the water pump every other change.
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
I have the entire kit for sale in classifieds. Interested?850Bill wrote: 28 Sep 2025, 06:43 What are the recommended timing belt/tensioner changes - Mileage/Years?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
- 1962 Views
Last post by RickHaleParker
- 10 Replies
- 2212 Views
Last post by Noah1798
- 1660 Views
Last post by frisky99
- 364 Views
Last post by chrism
- 430 Views
Last post by PA08S80
