Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
chaosrob
Year and Model: 1999 v70R
Has thanked: 37 times
Been thanked: 15 times
Re: Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading..
Post by chaosrob »
ty
scot850 wrote: 20 Sep 2025, 07:41 Your project is coming along really nicely, as the saying goes, if it is worth doing, do it right!
It is amazing what a transformation happens, even when just cleaning all the years of crud off.
Neil
chaosrob
Post by chaosrob »
Got the exhaust on today and added/topped off all fluids and ran it for quite awhile today, no leaks! Check engine light is on for downstream 02 sensor I am still waiting on the extension to be able to plug it in. On to the suspension and brakes now!
chaosrob
Post by chaosrob »
Has thanked: 1839 times
Been thanked: 1709 times
You are shaming many of us with how clean the underhood area is!
Neil
greg850r
Year and Model: a long list
Has thanked: 5 times
Been thanked: 22 times
Post by greg850r »
I have those 02 extensions laying around. I'm an hour SW of St. Louis.
05 Cross Country wagon
99 C70 Convertible
96 850R wagon
96 850T wagon
96 850 GLT 5spd N/A sedan -wrecked, ouch
97 850R 5spd sedan
66 GTO 421SD 4spd
67 GTO 455 T400
02 Powerstroke 4x4
85 Yota 4x4 (2)
24' 454 Challenger
07 Softail Custom
02 Sportster Custom -sold
Parts cars come and go
chaosrob
Post by chaosrob »
Had a few hours this weekend so went back to work on the front suspension on this thing, and of course more cleaning
New struts, tie rods, lower control arms, brake lines, brake calipers, rotors and pads, end links, etc, etc
I thought I was about done and put the drivers caliper on only to notice it is a passenger side caliper as well, flickers sent me two pass calipers instead of a drivers and passenger. I guess I will be on the phone tomorrow trying to get it straight. Car is looking pretty good and starting to see some light at the end of the tunnel
Last pic is before passenger side
CIK7
Year and Model: 95 854T & V70trailer
Has thanked: 320 times
Been thanked: 87 times
Post by CIK7 »
chaosrob wrote: 22 Jul 2025, 09:39 Hi all, just pulled a non running, rough 99 v70R auto out of a field in Missouri where it has been sitting since 2012. The car is 99% rust free but a non runner and is going to need a lot of work and parts to get it where it needs to be. I know I should run but I like a challenge. I will share along the way.
FP is dead do I get to tackle that first, I ordered the High Flow one from Vatt tuning, I have also preemptively ordered the timing belt kit with water pump, Pcv kit, new coolant hoses, spark plugs and assorted other parts from FCP. Passenger front window was smashed out so I replaced it.
I have a list of parts for sale in the classifieds. Let me know if you need something.
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
Has thanked: 1500 times
Been thanked: 3812 times
That’s looking really sharp, Rob. Those four bolt arms are a pain compared to the two bolt but a lift helps there
chaosrob
Post by chaosrob »
Thanks. Some of you guys are heroes that do this stuff on the ground and not a lift. This bots weren't bad for me because it was simple to put a screw jack under the engine/trans and jack the engine up with the mounts loosened, on the ground it would have been more of a chore for sure. The cleaning is kicking my rear, it takes more time than the mechanicals.
abscate wrote: 30 Sep 2025, 04:27 That’s looking really sharp, Rob. Those four bolt arms are a pain compared to the two bolt but a lift helps there
chaosrob
Post by chaosrob »
I took the advice from the board and replaced the coolant overflow, associated lines and the same with the power steering. Was going to do the brake fluid reservoir as well but the o rings are on back order.
Front is all buttoned up and have now moved on to the rear. I have replaced the two lateral links as the originals were very rusty. Probably would have been okay but I decided to just get them gone.
My rear brake hoses are very different from the ones FCP sent, hopefully they will still work,
Getting pretty excited as this thing is nearing the point where it can come off the lift and I can work on the interior and body, then off for an alignment
