Hy Guys,
2 years ago, i had to change brakes hoses hidden behind the fuel tank, to be able to succeed to have my french MOT. Unfortunatly, i couldn't change the second one. The old one was in good shape, so everything went fine. I had to move the tank.
Since then i can't fill the thank till the top cause some hose may have been unplugged by the operation, and i loose gasoline on the ground.
Here's the picture of my 850 model FT.
May someone tell me which hose i may have unplugged unfortunately ?
I do thank who will explain me this issue.
Manov
850 Petrol fuel tank question
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
Can you tell anything from looking at the tank from underneath ? I had a problem with part #12.
You could also look at the top of the tank through the access plate where the fuel pump is.
1999 V70 GLT
1999 V70 GLT
- 11 Replies
- 423 Views
Last post by vtl
- 9 Replies
- 4838 Views
Last post by matt_linegar
- 11 Replies
- 403 Views
- 152 Views
Last post by manovlov
- 2228 Views
Last post by volvoclueless
