Wife's super clean garage kept 04 v70 is needing an engine rebuild at 280k miles. She'd rather me refresh the drivetrain than get something newer.
I'm not seeing cam bearings in the rebuild kits so my question is how are the heads and cam dealt with during an overhaul.
I have past experience with two good machine shops for block/crank/rod work. But this will be my first non pushrod rebuild.
I've no interest in dropping a used engine in
Thanks in advance.
2004 v70 2.5t engine rebuild
22volvo
- Year and Model: 2004 v70
- Has thanked: 2 times
- Been thanked: 2 times
A rebuild kit for the B5254T2 found at:
https://partsology.com/products/engine- ... 5l-ek4264b
I have no idea of the quality of the parts as I'm just starting this pursuit.
VTI - I intend to zero time it. New bearings, rings and if needed oversize pistons, resized rods and crank grinding. Won't know till it comes apart and I mic it. Doesn't look like these OHC engines have cam bearings.
Do you know of a quality head shop recommendation?
The 04 has been garage kept with regular maintenance so a lot of low time parts will transfer (PCV, exhaust cam phaser, engine mounts). While 280k miles, the body and interior are clean enough to drop a fresh power plant in. Once the electrical gremlins (can bus issue) were resolved, these things are cheap to maintain.
The wife's 04 Volvo (in the background) is number two in the queue. I'll start that project after I complete the 08 Ford 6.4 PSD I'm currently rebuilding.
2004 v70 2.5T 286K miles.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
I would not use this kit. I got my engine parts mostly from FCP Euro. Used either Volvo or known OE, like Elring. But, again, your choice.22volvo wrote: 01 Oct 2025, 17:34 A rebuild kit for the B5254T2 found at:
The 04 has been garage kept with regular maintenance so a lot of low time parts will transfer (PCV, engine mounts). While 280k miles, it is clean enough to drop a fresh power plant in.
Do the measurement and decide where to go next, yes. The bores can't be re-sleeved, unless you go with exotics like Darton.
No cam bearings. If the head is warped too bad, you'll see wear on the valve cover.
I did the head in my own garage, on the IKEA table. Not a rocket science, just take your time. OTC 4572 spring compressor, straight edge and a piece of flat thick polished glass is all special tools that were really needed.
- DavidE7
- Year and Model: 01-07 V70, S60, XC70
- Has thanked: 67 times
- Been thanked: 93 times
Use a factory Volvo brand head gasket if you do the rebuild. I have had 4 FCP Euro head gaskets from Victor Reinz fail. The rubber coating they use is thicker and more flexible than the OE coating and wears away after about 40,000 miles resulting in a very slow coolant leak into the combustion chamber(s). These gaskets have had blue printing for "Victor Reinz" on the gasket surface. I am working with a guy that formerly worked for a gasket manufacturer and he said the aftermarket coating quality from the OEM suppliers is definitely lower than the original equipment to save money.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 231,000 miles
2004 Nautic Blue XC70 2.5T 258,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 277,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 203,000 miles
P2 Volvos for every person in my family
vtl
T2 is MLS gasket.DavidE7 wrote: 14 Oct 2025, 15:49 Use a factory Volvo brand head gasket if you do the rebuild. I have had 4 FCP Euro head gaskets from Victor Reinz fail. The rubber coating they use is thicker and more flexible than the OE coating and wears away after about 40,000 miles resulting in a very slow coolant leak into the combustion chamber(s). These gaskets have had blue printing for "Victor Reinz" on the gasket surface. I am working with a guy that formerly worked for a gasket manufacturer and he said the aftermarket coating quality from the OEM suppliers is definitely lower than the original equipment to save money.
- 9 Replies
- 1954 Views
Last post by Chuck W
- 30 Replies
- 5625 Views
Last post by jimmy57
- 1826 Views
Last post by huzzsaba
- 1792 Views
Last post by SuperHerman
- 11 Replies
- 3689 Views
Last post by Salomons Driveway
