We have it another hour today
Reproduced symptoms. Scanner reads VIN from CDM, and parameters from dash show up and change as toggled
Engine temperature reported as -40C bottom of range. Noted from wiring that the ECT reports directly from the ECM so that also points to a non responsive ECM (not necessarily non-working)
We swapped in Jane Bonds ECM, for a 2000 NA m56….same symptoms
We checked the CANBUS Aline’s for, CDM to ECM for continuity , all good
Then I noticed the main relay was not pulling in. 850 LPT comfirmed this.
We jumped it with a paper clip, no joy.
Then the relay started pulling in again?????????
Could that be the intermittent ???
99' S70, 5-speed, Immobilizer Problem. End of the road for Matilda?
- Has thanked: 1611 times
- Been thanked: 4073 times
- Has thanked: 2210 times
Try this link for P80 S70 NA wiring diagrams:
https://portal-diagnostov.com/en/root/r ... -diagrams/
Behind paywall. $20 to get pdfscot850 wrote: 04 Oct 2025, 10:12 Try this link for P80 S70 NA wiring diagrams:
Sorry about that, strangely when I tried first time it went straight in. Should have copied the files. I'll look some more and try to extract from Vida. I seem to recall I had issues accessing wiring diagrams last time I tried.
Ok, these 2 have access to the diagrams. The first has a free 3 day trial. and the 2nd is the Norwegian Volvo Club:
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://forum.vccn.no/dokumentasjon/Vol ... n_3_39.pdf
Note. Mathilda’s ETMclicks on power up but does not run the complete self-test I am used to.
Video here
viewtopic.php?p=632156&hilit=ETM+video#p632156
Video here
Moved Neil’s post….
Yup. that is not what it should be doing. The possible issues I am sure you have considered are:
1) ECU - I believe you have swapped in an alternate to see what happens. I assume you have the same result with that.
2) ETM - If you have not swapped that out, that is where I would be looking to or a wiring issue to the ETM from the ECU.
Swapped in both Shaggs and Jane’s ECU and no communication to either. We are going to try Mathilda’s ECU in a good running car.
Here is the harness tracing diagram , eeeks
Good thing I happen to have a complete stripped out DENSO harness in my garage….
- Screenshot 2025-08-05 at 08.28.12.png (576.84 KiB) Viewed 244 times
- 25 Replies
- 6546 Views
Last post by FireFox31
- 10 Replies
- 4529 Views
Last post by tfo
- 2613 Views
Last post by SeanyB
- 18 Replies
- 3703 Views
Last post by beigg
- 15 Replies
- 4451 Views
Last post by wizechatmgr
