Thank you!
The Amazon order arrived - Two-Way Articulating Borescope with Light.
The car is sitting on curbside since the original post date -- 10 days or so -- can it be started and moved into our garage for diagnostic and....
2001 V70XC - Blue smoke from tail pipe...
xHeart
- Year and Model: 2.0/3.2
- Has thanked: 116 times
- Been thanked: 119 times
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
I would move it before tearing into anything, don't wait for it to warm up.xHeart wrote: 03 Oct 2025, 09:51 Thank you!
After everything is hopefully fixed run cataclean through it.
xHeart
Ty Vtl: It has run on Pennzoil 5W40 for 8 or so years with a yearly oil and filter change around 6000 miles. I would love to share with you what I'd see with Borescope.vtl wrote: 17 Sep 2025, 04:58 "High mileage" oils cause seals to swell. Carbonized piston rings can't be cleaned in any other way but mechanically, and it takes a lot of efforts to do so. In your case oil was dripping into cylinders via valve stem seals.
- 10 Replies
- 1765 Views
Last post by erikv11
- 47 Replies
- 8058 Views
Last post by WhatAmIDoing
- 5117 Views
Last post by darrylrobert
- 21 Replies
- 9031 Views
Last post by - Pete -
- 1285 Views
Last post by Canadian850
