I think I know what the issue is but would like further information and advice. I have a front right brake caliper that is sticking. It is dumping a lot of brake dust all over the wheel, the other 3 are squeaky clean since I washed all 4 wheels only a few weeks ago. When I replaced my front struts about a month ago I found that the caliper pins on that corner had no lubrication, so put some lube in there thinking I solved the mystery but alas, I didn't.
At this point I think the caliper itself is freezing up. Does this sound correct? Is there a recommended supplier for replacement calipers? I have new brake hoses to go with this repair.
Here is a photo I just took of it. This wheel was completely clean a few weeks ago.
Sticking Brake Caliper - 2000 V70
- rolsen11
- Year and Model: 00 V70, 04 S60R
- Has thanked: 57 times
- Been thanked: 58 times
2000 V70 SE - Bought sight unseen in Cleveland, no longer my only car. Looks identical to my profile picture
2004 S60 R - M66 "Spaceball" manual transmission, Atacama "orange" interior, Titanium Gray metallic
You might find a fresh set of pads will push the piston back into clean metal in the caliper but usually once they start sticking it doesn’t bode well. Centric are decent and are often rebuilt on Volvo cores.
jmartin919
- Year and Model: S70 GLT SE 2000
- Has thanked: 97 times
- Been thanked: 42 times
Could be a bad brake hose.
'00 S70 GLT SE
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
'82 MB 380SL
'11 MB E350 Sport
'84 Chevy C10
'93 850 GLT NA SOLD
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I had a sticking caliper on my 99 S70 one day on the way to work. I took it back home, and jumped in the 850.
When I got to working on the S70, I planned to replace the caliper, but the ordered caliper was incorrectly rebuilt. My solution was to pull apart the original caliper, clean it, and reassemble it. The only new parts I used were pads, and the hose. No problems after that.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
This awesome post by FireFox is recommended reading for brake calipers failures and options for repair/rebuild.
viewtopic.php?t=102449
- rolsen11
Planning to head to my local NAPA to get a new caliper, I've had good luck with NAPA so I trust that their rebuilt calipers are decent after reading about it. Thanks!jreed wrote: 10 Oct 2025, 05:35 This awesome post by FireFox is recommended reading for brake calipers failures and options for repair/rebuild.
- jreed
I put rebuilt Napa calipers on the rear brakes of my 97 855 last year and so far they have been working fine with no trouble noted.
- rolsen11
Done! Things are starting to look shiny again
- jreed
Looks great! Looks like brand new brake lines too.
- rolsen11
Yup, new line. I have another one to install on the drivers side too. I have an iPD shipment arriving on Monday for new steering rack boots, backing plates/dust shields, and a new CV axle boot for the drivers side. If I have time I'll put that new brake hose on too when I get that other stuff installed. I feel like I've done a lot of replacing in the last year, lol.
- 1401 Views
Last post by kurts2
- 38 Replies
- 6913 Views
- 818 Views
Last post by br0dy519
- 3167 Views
Last post by styoung94
- 15 Replies
- 6475 Views
Last post by wizechatmgr
