1999 S70 AWD surging under load karlaKat
- Has thanked: 1611 times
- Been thanked: 4074 times
My coils were stamped 9837 which means 37 week of 1998 - probably original to production date of the car, late 1998, 1999 model year
Might have time to swap in a used turbo control valve today to use the parts cannon approach
- Has thanked: 2210 times
What makes you think it may be the TCV and not the ETM? The problem 07 C30 T5 I was trying to help with had an occasional surging idle at rest (not noticed while moving). It has had a used and a brand new TCV and no change. Still turns up randomly. The issue may not be the same for your car I appreciate. Do you have a spare ETM for an LPT engine? If not I am sure I do. Can't do anything for a week though until I get back to Calgary.
Got some data.
Throttle position is showing glitches and throttle body error codes.
I’m not sure she is boosting well , photo of data on a pull
It’s an original!!! Year 1998 ETM
Picking up some throttle body codes. I’ve got a UBG S70 AWD ETM from the Kat
Straight swap. Unfortunately as you and I predicted it is the likely cause. PITA to swap on a turbo, but not too terrible. Good luck!
I have a bunch of LPT ETM's if your spare does not work.
I swapped out the Kats yellow sticker trying to fix a problem of “ failure to proceed due to lack of fuel “ problem
Oh, no! Not again...................
Update. The temps have fallen into the civilised 5-15 Celsius and the surging has stopped. My guess is it’s temperature sensitive to the ETM, so I’ll drive and monitor this winter
- 12 Replies
- 995 Views
Last post by JHarkness
- 2212 Views
Last post by Reys
- 2406 Views
Last post by sleddriver
- 11 Replies
- 3261 Views
Last post by traudesa
- 14 Replies
- 2994 Views
Last post by Cookeh
