2024
Very hard starting, crank no fire
Cam sensor code, oil leak from cam cover bolt making a mess.
Coding P0343 and P0014 , need to get timing set
Swapped in UBG cam sensor DENSO still codes
16JAN2025 NYSI passed at 261xxx
1999 V70 T5 M56 ELIZABETH 578465 Nautic Blue 417 Perfo 16 Wheels
Forum rules
Too much work so I called in the pro help. Running with the Spinner, he put in 6 Timeserts and reglued my head back on Elizabeth.
Great to get her back on the road.
Nov 1 .. replaced clutch hydraulic hose , 3 hours
viewtopic.php?t=68726
viewtopic.php?p=669927&hilit=Elizabeth+clutch#p669927
Have to fix glovebox latch and bleed brakes this winter
cuhfs
- Year and Model: 850,XC70,XC90,S60,80
- Has thanked: 17 times
- Been thanked: 31 times
Robert DIY is the GOAT
04 C70 Convert Auto
06 XC90 Auto (ORE) #401/800
06 S80
05 S80
12 S60
04 XC70 Auto (Parts car)
04 XC70 Auto (gone)
04 C70 Convert (gone)
06 S80
05 S80
12 S60
04 XC70 Auto (gone)
2026 repairs
NYS I 15 Jan 261600
Reverse lights out? Bulbs voltage fuse m56 switch
Bought Febi m6 reverse light switch fcp
22 mm deep to remove and replace
Pushed 250 ml brake fluid both front calipers.
Driver bleeder snapped
Bled left caliper out at hose. Bought replacement ftom FCP
Ac charge leak? Inspected evaporator, ok
viewtopic.php?t=78410&start=12040
Condensor is alarming fir r134a leak at ports and at grill
Pulled right rear wheel. Replaced frozen right rear caliper. New Volvo pads. New rear rotor
Could not get rotor over new parking brake shoes. Bled 250 ml fluid. Parking brake inop
NYS I 15 Jan 261600
