No. I did not. I didn't want to do any more crawling under the car. I'm old and I get dizzy when I'm lying down underneath the car for long periods of time.
I wouldn't doubt it is the leak detection pump or electrical wiring for the "correct" factory fix.
P0455 - Should I fix it?
Surfmullet
- Year and Model: 2001 Volvo S60 2.4T
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
The test I mentioned is within the VIDA software. No climbing under anywhere except dash to plug in DICE. Commonly this pump fails and reports a leak. Also I believe there was a software update for this module / pump as it originally detected a fault at too low of tolerance.
I don’t believe restricting your vent charcoal filter should ever be necessary.
Maybe someone near you in WA can assist. I’m sure abscate wouldn’t mind driving from the east coast.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- Been thanked: 4069 times
I would love to but I’m on the wrong side of the Atlantic eating Danishes.br0dy519 wrote: 23 Oct 2025, 19:28 The test I mentioned is within the VIDA software. No climbing under anywhere except dash to plug in DICE. Commonly this pump fails and reports a leak. Also I believe there was a software update for this module / pump as it originally detected a fault at too low of tolerance.
Maybe someone near you in WA can assist. I’m sure abscate wouldn’t mind driving from the east coast.![]()
- Has thanked: 987 times
- Been thanked: 1076 times
Don't fix it. Just keep clearing the code to turn off the light.
Unless you live in a place that punishes you have having emissions codes set. Then move to another place!
volvolugnutr
volvolugnutr
