This seems too good to be true:
https://www.ebay.com/itm/135199870360?f ... BMnrXI6cRm
Exhaust replacement - Cat/resonator flange rotted out
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
New OE DP costs exorbitant money. The affordable ones are made of thin cheap steel and cheap ceramic converter, which your rear oxygen sensor will dislike. I have a good quality 3" downpipe that has a cheaper converter, and the only reason I don't get a cat efficiency code is my ECM tune that ignores the downstream sensor altogether. But I can tell by smell that this aftermarket CAT is not anywhere near the expensive metal one that Volvo used.JayPea44 wrote: 27 Oct 2025, 10:52 This seems more expensive than just getting a new down pipe. My FIL is a welder, maybe I can ask him.
Bring a 6-pack to your FIL, welding an old car with a relative is a good bonding experience
JayPea44
- Year and Model: 2007 xc70
- Has thanked: 36 times
- Been thanked: 6 times
Yep the OE ones are thousands and the price of affordable one makes me think they're essentially junk. I'm going to go with some kind of bracket to hold it together for now then have the FIL weld it when he can. He's retired now so needs something to dovtl wrote: 27 Oct 2025, 10:57New OE DP costs exorbitant money. The affordable ones are made of thin cheap steel and cheap ceramic converter, which your rear oxygen sensor will dislike. I have a good quality 3" downpipe that has a cheaper converter, and the only reason I don't get a cat efficiency code is my ECM tune that ignores the downstream sensor altogether. But I can tell by smell that this aftermarket CAT is not anywhere near the expensive metal one that Volvo used.JayPea44 wrote: 27 Oct 2025, 10:52 This seems more expensive than just getting a new down pipe. My FIL is a welder, maybe I can ask him.
Bring a 6-pack to your FIL, welding an old car with a relative is a good bonding experience![]()
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
those split couplers are rather flimsy, I bent several of them before finding something more solid, same idea. (link below).JayPea44 wrote: 27 Oct 2025, 11:05 Looks like I don't have to make it myself - this is exactly what I was envisioning.
https://www.autozone.com/emission-contr ... 110783_0_0
You will very likely need longer bolts, stainless.
Clean the flange mating surfaces with a hand held belt sander (it can be done in place but use goggles)
hi-temp RTV , I doubled up the gasket, glued together with a thin smear of RTV overnite.
Support the joint when doing the final cinch up, I used a trolley jack sitting on a milk crate to lift it into alignment then final tighten the nuts.
Be aware the pipe might measure the typical 2.5 inch but theres a raised reinforced shoulder at the flange so get that measurement, not the pipe itself.
VTL is right about buying a mig, especially with a weldor in the family to teach you.
With all the horsing the system around I broke the flex pipe and had to weld a new one in.
I had to buy a tank of argon/C25 gas as flux wire burns hotter and I couldn't see the weld joint.
this link is for flat oval pipe, find the one for round exh pipes instead .
Can't recall if the pipes are flat oval or round, its been 2 years and it held up fine.
https://www.amazon.com/EVIL-ENERGY-Exha ... 9hdGY&th=1
vtl
Need a better helmet? This one is freakin' awesome, I can see everything now: https://www.amazon.com/dp/B076H4MWDSjonesg wrote: 27 Oct 2025, 19:29 I had to buy a tank of argon/C25 gas as flux wire burns hotter and I couldn't see the weld joint.
VanBoisvert
- Year and Model: 1995 Seat Marbella
Es ist leicht, den Ueberblick zu verlieren, weil es so viele Gaming-Seiten online gibt. Ich lese gerne ueber Alawin Deutschland casino zusammen mit anderen Plattformen, damit ich die Funktionen vergleichen und eine besser informierte Entscheidung treffen kann.
JayPea44
Thanks - that's the exact ones I have in my amazon cart right now.jonesg wrote: 27 Oct 2025, 19:29those split couplers are rather flimsy, I bent several of them before finding something more solid, same idea. (link below).JayPea44 wrote: 27 Oct 2025, 11:05 Looks like I don't have to make it myself - this is exactly what I was envisioning.
A welder is definitely in my future. I just want to get this on right now. I've done a little migraine welding in the past so hopefully I remember the most of it and my FIL can give me some better tips.
A trip to Harbor Fright for a welder might come sooner rather than later.
I did see something like this which would work a lot better if/when I can weld it on
https://www.amazon.com/FGJQEFG-Hardware ... F0aWM&th=1
- 882 Views
Last post by Herb Goltz
- 3397 Views
Last post by DGB47
- 531 Views
- 369 Views
Last post by rjS60Turbo
- 620 Views
Last post by SuperHerman
