Chaosrob 1999 v70R 601 save, Going to need a lot of parts, lot of help and do a lot of reading.. Topic is solved
chaosrob
Year and Model: 1999 v70R
Has thanked: 37 times
Been thanked: 15 times
Post by chaosrob »
Another busy week, all I got done was the bumper/headlight/wiper/undertray. Feels really good to finally have the front back on it though, looks like real progress.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Wow, very nice!
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
chaosrob
Post by chaosrob »
Thank you
454cid wrote: 26 Oct 2025, 19:05 Wow, very nice!
Been thanked: 4071 times
This is a sweet, sweet restoration.
chaosrob
Post by chaosrob »
Well after getting it back together and taking it for a short drive I now know why it was parked. The rear diff is shot on this thing, sounds like a cement mixer full of marbles. Removed the VC and turning it by hand results in binding and noise. Now faced with two choices, pull it back apart and redo half the work I have already done or just throw in the towel and scrap it. Yes, I know I can just make it FWD but it would annoy the hell out of me knowing that it isn't right and is bandaged. For now I am just going to pull it outside and get back to work on the GTO until I make a decision.
Has thanked: 2205 times
Been thanked: 1852 times
Are you certain it is the diff and not the nose bearing in the VC unit? They fail but other than needing a long punch they are easy compared to what you have done to repair. Diff is a lot more work as the stupid design requires the rear subframe to be dropped to open the top of the cage to remove it. Totally stupid. Shame you are not closer as I have a diff and a couple of VC units in the stash.
chaosrob
Post by chaosrob »
100%, I removed the VC and turning the diff with it removed results in binding and noise from inside. The VC would be much easier as I have a spare one right here. Bangs head on wall
scot850 wrote: 11 Nov 2025, 15:20 Are you certain it is the diff and not the nose bearing in the VC unit? They fail but other than needing a long punch they are easy compared to what you have done to repair. Diff is a lot more work as the stupid design requires the rear subframe to be dropped to open the top of the cage to remove it. Totally stupid. Shame you are not closer as I have a diff and a couple of VC units in the stash.
Of course it will be the diff! With an R it is never easy...................
Time to find an awd scrapper and get you a diff on the cheap.
have you already dropped the rear axle subframe for the other work? If you know its free, it is about 4 hours to get that down again and open up the 'clamshell'
We dont have a lot of knowledge about AWD and R diffs on the P80 series here, maybe that needs some research.
It does ****appear**** parts are available for internal diff stuff...
https://www.volvopartswebstore.com/show ... veLine=457
Patterson auto wrecking in Cohoc. PA - listed at ~ $300 delivered?
I also just remembered my Albany Crew has a 1999 XC upstate which in a holding pattern of either repair or part out. THats another source of parts potentially. Ill PM you.
