VS M4.4 tuning dead? Start again here?
Chuck W
Year and Model: 97 854 T5
Has thanked: 97 times
Been thanked: 340 times
Post by Chuck W »
xnRS wrote: 01 Nov 2025, 03:46 Just two 0 Ohm 0805 resistor are missing,
I'm assuming you left out a digit or two here?
I remember seeing that discussion in the VS thread.
kingartur
Year and Model: 1997 volvo 850
Has thanked: 3 times
Post by kingartur »
Chuck W wrote: 31 Oct 2025, 19:39
kingartur wrote: 31 Oct 2025, 19:02 I think I've found the issue, my M4.4 ECU is from a NA version. From what I've read it seems like the M4.4 should be from a Turbo version
Do you think that matters?
It absolutely matters. The NA ECUs don't have the components populated on the board for the TCV control.
Just two 0 Ohm 0805 resistor are missing, and one 2.2k 0805 resistor should be removed. Their pads are easily traced via multimeter, or you can search VS thread for the photo of pads
Is there anyway that you can help me with that?
How do I find the thread?
Chuck W
Post by Chuck W »
The discussion and pics for the mod should be HERE. (I used the (site search in Google, as the search on the website itself kinda sucks)
I was wrong and they are ZERO Ohm resistors (so jumpers basically)
xnRS
Year and Model: 1994 Volvo 850 2.5T5
Has thanked: 7 times
Been thanked: 5 times
Post by xnRS »
Chuck W wrote: 01 Nov 2025, 16:08 The discussion and pics for the mod should be HERE. (I used the (site search in Google, as the search on the website itself kinda sucks)
Yup, this is the one.
1994 Volvo 850 T5
Italian spec, originaly 2.0 T5, early facelift with OEM RIP kit, early dash buttons and etc.
Previous Owners swapped 97' B5254T
Mods: Titan R17 Rims, Japanifold, Motronic 4.4 with S70R Tune
kingartur
Post by kingartur »
https://prnt.sc/lkwWal7r2Y1r
This is my NA ECU, but it is different from the one on the link you sent me. Seems like is missing a chip.
Do you think it will be able to "solder" to transform this NA to turbo version?
Chuck W
Post by Chuck W »
That chip isn't a needed item. Not sure what it is, but it's not on a few of the turbo boards I've looked at.
There should be no problem with mod the board you have. They're surface mount components, and there is already solder on the pads on the board.
Can you post a pic of the label from the ECU?
kingartur
Post by kingartur »
After using the multimeter is seems the B41 (TC) is connected to the pad of the missing chip. The one missing on the green circle: https://prnt.sc/6MWUiIyI5DZ1
This is the label: https://prnt.sc/zrdT6vi6KVWK
Thanks very much for your help.
Chuck W
Post by Chuck W »
As I said, it shouldn't matter.
This is a 98MY S/V70 M4.4 LPT turbo ECU, and it doesn't have that chip either.
kingartur
Post by kingartur »
I'll do it and I'll tell you if it worked. Thanks very much for your help.
S23
Year and Model: 1997 Volvo S70 T5
Post by S23 »
Has anyone installed a live eprom editing emulator? E.g. Moates Ostrich 2.0 or Cobra RT?
