I'm assuming you left out a digit or two here?
I remember seeing that discussion in the VS thread.
xnRS wrote: 01 Nov 2025, 03:46Just two 0 Ohm 0805 resistor are missing, and one 2.2k 0805 resistor should be removed. Their pads are easily traced via multimeter, or you can search VS thread for the photo of padsChuck W wrote: 31 Oct 2025, 19:39It absolutely matters. The NA ECUs don't have the components populated on the board for the TCV control.kingartur wrote: 31 Oct 2025, 19:02 I think I've found the issue, my M4.4 ECU is from a NA version. From what I've read it seems like the M4.4 should be from a Turbo version
Do you think that matters?
Yup, this is the one.
