Sometimes my Volvo makes a loud repetative clicking noise when idling. It seems to do it more when I have just started it up. If I rev it while stationary, the noise goes away above 1k rpm.
It also seems to get worse when the a/c compressor is running. Sometimes the noise cycles with the A/C. Other times I can hear it with the A/C off and, turning it on makes it worse. The A/C works well after I did the zip-tie/bread clip trick.
I also hear a similar, but non-repeating crack noise when pushing down on the passenger side (as if I were testing the suspension), but that could be a different issue.
With the belt cover off all of the pulleys look fine even when the noise is occurring.
Here are some videos that show the sound.
In this video, the noise stops when the A/C stops cycling.
What could this be? A failing A/C compressor? It has been doing this for a while.
Loud clicking noise on idle
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Stethoscope or long screwdriver on VVT solenoids and listen. Also look at t-belt and serpentine belt tensioners, they shouldn't jerk violently. T-belt's one is a bit more agile, though.
gavolvoman
- Year and Model: 2009 S60
@02V70 Did you ever find out what caused the ticking noise? My Volvo is doing the same thing. 2009 Volvo S60.
- Been thanked: 504 times
- I'd stop driving the car if I hear that noise, then
- Check service records, then
- Check every single pulley involved by removing the belt(s)....
- PS pulley, Alt pulley, AC compressor pulley, tensioner pulley
- For the TB area: both pulleys, WP pulley
- 02V70
- Year and Model: 2002 V70XC
- Has thanked: 53 times
- Been thanked: 40 times
Yes, It was the belt tensioner. I have no idea why it was making that noise, but replacing it and the pulley that was on it fixed the issue. I noticed the pulley on the original tensioner was not rotating smoothly, so I replaced it, but it did not fully solve it until i replaced the tensioner.gavolvoman wrote: 08 Nov 2025, 00:28 @02V70 Did you ever find out what caused the ticking noise? My Volvo is doing the same thing. 2009 Volvo S60.
2002 v70 X/C 288k miles
- 10 Replies
- 3866 Views
Last post by 800artfreed
- 11 Replies
- 524 Views
Last post by erikv11
- 1804 Views
Last post by dcarlson12
- 2749 Views
Last post by velorider
- 750 Views
Last post by Cees Klumper
