11A/14 = Fuse 14 in Engine compartment.
2/7 = Starter Relay under dash drivers side.
3/1 = Ignition switch on Column lock.
8/16 = Transmission lock out switch on transmission (Automatic only).
4/18 = Immobilizer ( Controls grounding to the Starter relay)
6/6 = Starter motor.
2001 Volvo S40 remove ignition switch .. trying to fix no crank no start
- RickHaleParker
- Been thanked: 978 times
Active
Past
Past
Hi, currently facing the same issue. Second key position turns on everything but fuel pump, headlights, climate controls, and third position doesn't crank or do anything aside from dim lights and turning off the radio. Am I having the same issue and how was it solved?
Hello, i have also column lock problem. I am going to replace it with starter switch, but i am not sure which wires i need to connect. Have read some other forums and there are different coloured wires each one suggest
Mine connector has blue, White and blue, black and blue, White, yellow and black wires. I can see that yellow and black goes to starter so i assume that is one but which is the another one?
Thank you for your assistance:)
- 3486 Views
Last post by Empathron
- 2639 Views
- 11 Replies
- 1082 Views
- 13 Replies
- 2940 Views
Last post by Hoser99
- 5607 Views
Last post by Volvoblackdog
