Just replaced the upstream O2 sensor on the 2001 V70XC (because of engine code). Pulled it out an am a little unsure of the look of the sensor - could just be "this is what they look like after 200k miles" or could be something wrong (though it doesn't seem to be "gunky" enough for coolant leak).
I am a bit more concerned because this car was giving me lots of misfires at startup over the summer, but pulling the car keys off of all my other keys (actually splitting it into 3 more manageable rings) made that and the "no throttle response" issue go away, so I don't think it was from a damaged head gasket. Oil also shows no signs of coolant contamination (and vise-versa), and while I did have to top up the coolant a bit recently the cap wasn't sealed so may have just evaporated off.
Seems closer to silicone really, but I haven't used any silicone on the car.
upstream O2 sensor - is this coolant? - 01 V70XC
Absolutely normal for an in use OXS
- 1180 Views
Last post by Thunderbox
- 3207 Views
Last post by VolvoBooster
- 1562 Views
Last post by sleddriver
- 1114 Views
Last post by RickHaleParker
- 941 Views
Last post by davidisurf
