Went to put a curt hitch in the XC90 and had some fit Rt trouble. I suspect it’s build tolerance.
Opened tech support ticket
2013 xc90 curt hitch install
- Been thanked: 4063 times
Update. E-trailer responded in two hours and will send me a new one.
Ups picked up mine, and etrailer shipped the replacement same day. Good customer service
Got new hitch on this am, in 50 minutes.
It uses 4 existing m12 bolts on car, and includes 2 more m12 bolts (threads already in frame rail )
Exiting bolts are 15 mm hex, new ones are 19 mm
You need to remove rear exhaust donut and the two exhaust donuts upstream
Torque on bolts 100 Nm
Rear fascia trim needed
Silicone spray those donuts to make reinstall with hand pressure easy
- BlackBart
- Has thanked: 967 times
- Been thanked: 921 times
The hitch on my 850 came from E-trailer long ago. I was quite pleased with it.
- 642 Views
Last post by br0dy519
- 1526 Views
Last post by superfeed
- 2066 Views
Last post by Herb Goltz
- 752 Views
Last post by 850oldschool
- 1330 Views
Last post by ReedTX
