no heat - winter is coming.
- Antoine240bk
- Year and Model: XC70 2.5T-2006 - 4C
- Has thanked: 12 times
- Been thanked: 30 times
2006 XC70 2.5T - 291.000 km , it had new radiator, hoses, coolant tank fitted last spring
Volvo XC70 2.5 T AWD P2 B5254T2 - 12/2005 Four-C Previous : Volvo V70 P1 2.4l 20s 170ch B5244S 03/2000 - Volvo 245 GL Break 1979 B21 -LPG - Volvo 240 GL Break 04/1992 B230F (Daily for 14 years)
gabejones
- Year and Model: 2007 S60
- Has thanked: 2 times
Okay, I got the gun, took the measurements. With the car running hot, the heater and blower were off, the measurement was very close together. 90C on the right, 86C on the left, with the laser on the plastic elbow as shown. After turning on the heater to max, the air was initially a tiny bit warm. After checking the hoses with heater on full, the left side hose temp dropped gradually to 63C after a couple minutes. At that point, the air from the vents was barely above ambient, which was a pleasant 12C
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 534 times
in kansas? no way I'd touch that without a heated garage til May.
A $20 aux heater should get you byif you don't want to pay a shop.
https://www.amazon.com/Portable%EF%BC%8 ... 0aWM&psc=1
- Been thanked: 504 times
At this mileage, I'd replace:
1. Tstat (Wahler is OEM ~ $90, Facet is excellent too for $55).
2. HC is Behr but NLA.
In the past, I have used the seller on eBay selling Estonia-made HC for P80 1998 S70. I have not tried Estonia HC for P2 yet.
- Been thanked: 4071 times
10C is my limit too, but for me its <10C....
- 8FD9F8E9-CCD6-4078-BCBF-31F113E2082A_1_105_c.jpeg (66.99 KiB) Viewed 591 times
- The 2005 XC90: replaced the HC (Behr) in 2017 @ 109K miles, 8 yrs ago. It was producing luke warm heat,
not hot. New HC and new tstat solved the problem. So far so good.
- The 2007 S60: replaced the HC (Behr) in 2022 @ 115K miles. It worked fine but I replaced it, just preventive
job. No issues so far.
- The 2006 S60 with ~ 112K miles...still good heat, so I am sitting on it for now until I find a Behr HC.
Or maybe Estonia HC.
PS: I am usually not crazy about Chinese car part, but the 2007 S60 came with Spectra Radiator CU2805, made
in China (P.O. had a shop put it in) in 2016.
Nine (9) yrs later, the Spectra radiator is working fine, no leaks. So I wonder if Spectra HC is as good???
gabejones
Hello Jonesg!jonesg wrote: 17 Nov 2025, 05:36 in kansas? no way I'd touch that without a heated garage til May.
I can always open the door to the house and let it warm up the garage
- 22 Replies
- 7690 Views
Last post by vtl
- 3032 Views
Last post by Speeds87
- 549 Views
Last post by Flyingdutchman
- 577 Views
- 2160 Views
Last post by benrk
