2004 XC70 driver's side headlight wiper-- which wiring harness?
Herb Goltz
Year and Model: 04& 06 XC70, '12 s60
Has thanked: 7 times
Been thanked: 5 times
Post by Herb Goltz »
Hi All,
My 2004 XC70's driver's side headlight wiper is giving up the ghost and blowing the 15A fuse it shares with the washer pump. There's a wiper delete project in my future, but now it is snowing and cold here. I know that the bumper cover has to come off to do a full delete of the wiper assemblies, but I am hoping I can unplug the harness to the driver's side for now. It looks like there is a harness with a red, yellow and black wire in it that looks like it could go to the wiper motor assembly. Can anyone confirm that this is the correct harness to unplug?
2012 s60 t5
2006 XC70
2004 XC70
Been thanked: 504 times
Post by cn90 »
Pull the relay in the fuse box and say goodbye to this useless feature.
I did that 10 yrs ago, label the relay "HL wiper" and leave it lying around in the fuse box.
Herb Goltz
Thank you-- that's a simple solution for now!
2012 s60 t5
2006 XC70
2004 XC70
Herb Goltz
I pulled the relay, but it also controls the wipers, so that didn't work. I found the connectors under hood after looking at one of Neil's posts that confirmed that the wires to the wiper motors are red, yellow and black. I need to figure out how to cap the washer fluid line, but at least my windshield wipers and washers work as it is snowy and slushy in the Toronto area!
2012 s60 t5
2006 XC70
2004 XC70
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
Herb Goltz wrote: 07 Dec 2025, 11:44 I pulled the relay, but it also controls the wipers, so that didn't work. I found the connectors under hood after looking at one of Neil's posts that confirmed that the wires to the wiper motors are red, yellow and black. I need to figure out how to cap the washer fluid line, but at least my windshield wipers and washers work as it is snowy and slushy in the Toronto area!
if it's similar to the 2001 there's a T off near the pump under the fluid tank, just switch it out for an elbow
Post by cn90 »
Idk about XC model but this diagram below is for 2006 S60.
Did you remove the correct relay?
fuse relay locations 2006 volvo s60.jpg (55.04 KiB) Viewed 240 times
