High beams randomly switching on itself
- jreed
- Has thanked: 384 times
- Been thanked: 221 times
I haven't heard of this symptom before. The closest description I could find:
viewtopic.php?t=40098
- Has thanked: 987 times
- Been thanked: 1075 times
I think the switch may have gone bad. I have had to replace a couple headlight switches on other cars at high mileage because they started to malfunction.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
Not on my Volvo, but on my Cadillac... the high beams would come on with my right hand turn signal. Apparently, the switch shorts internally. It suddenly started doing it, and got worse over a period of a couple of weeks. I pulled the high beam fuse until I could get a new headlight-switch/turn-signal-stalk installed.
I've never had a Volvo headlight switch out before. I wonder if it could be disassembled and cleaned. I did have to do that with my truck many years ago. That was a dome light problem. If you do, do that... don't lube it with Vasoline, like I did. It melts.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2200 times
The actual headlight switch was a recall issue many years ago for the units failing and causing random issues.
Try to find a junkyard one and swap it in and see if that fixes the issue.
Another other issue can be the stalk itself. The contacts can become worn or dirty. It is worth removing and cleaning the contacts.
svetjana
- Year and Model: 1994 850
- Been thanked: 2 times
Seems like it worked when I opened headlight relay and soldered some bad connections. On Monday it happened at least 5 times, on tuesday one time when driving to work. But at work i did this and to this day it hasnt happened. I will reply asap if it comes back.
- 884 Views
- 1392 Views
Last post by chiefpontiac
- 1729 Views
Last post by bahara07
- 2359 Views
Last post by msyverts
- 875 Views
Last post by cn90
