can heater hose be used for brake booster vacuum line?
JimBee
Has thanked: 33 times
Been thanked: 43 times
Post by JimBee »
It's time to replace that line but I'm not finding dedicated vacuum hose at auto supply stores.
Suggestions?
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
I used some sort of yellow sprayer hose from Lowes years ago. I think it was a fiber reinforced vinyl. It's was on my 69 Buick, and I think it's still there. I was contemplating replacing it, but I don't think I actually did so.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
Been thanked: 4071 times
Ping me jim, I have this as a spare. This one has to be heavy wall application for safety. Heater hose might work short term but you don’t want this to age and collapse.
JimBee
Post by JimBee »
Abscate: thanks! I just sent you a pm with my info. Looking forward to follow up.
JimBee
jreed
Has thanked: 384 times
Been thanked: 221 times
Post by jreed »
I used thick wall silicone tubing on my 97 855. The thick wall prevents collapse under vacuum. So far it has been working fine.
Can't remember if I used the 8 or 10mm diameter hose:
https://www.verociousmotorsports.com/ve ... &size=1131
Grantkat
Year and Model: 1999 s70 GLT
Has thanked: 59 times
Been thanked: 54 times
Post by Grantkat »
I haven't had the need to replace a brake booster yet, but in the past I have used re-enforced fuel supply lines when the part could not be sourced. Also most auto supply stores brake booster line by the foot just make sure it has re-enforcement within it and rated for pressure.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
On its way , Jim. It’s heavy wall tube..
jimmy57
Has thanked: 5 times
Been thanked: 322 times
Post by jimmy57 »
Auto Trans Cooler line IS suitable due to stiff construction. Fuel hose and other hoses at the auto stores are too soft.
