I keep having this problem as soon as I hit 1/4 tank petrol. The car will have barely any throttle and it will either end up stalling or be fine if I sit for a few mins.
If I turn the car off and back on after a few mins I’ll be able to drive for another 10-20 mins before it happens again.
I’ve changed the fuel pump to a Bosch one, changed pressure sensor to a Bosch one, changed fuel filter to a Mann filter and the pump module attached to the tank
Any help would be amazing!!
V70 T5 losing fuel pressure and throttle at 1/4 tank petrol
Alfiehiron
- Year and Model: 2005 v70 t5
Alfiehiron
How does that side work? The wiring for it looks like it’s only job to is measure the level on that side?
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
Yes. You may be running on fumes, while the sending unit still says there's 1/4 fuel left.Alfiehiron wrote: 20 Dec 2025, 11:30 How does that side work? The wiring for it looks like it’s only job to is measure the level on that side?
Alfiehiron
I opened it up at 1/4 and looked in and there’s plenty of fuel in there.
vtl
Fuel line between halves is not kinked? Need to route it supercarefully, or you'll be starving the fuel pump.Alfiehiron wrote: 20 Dec 2025, 12:13 I opened it up at 1/4 and looked in and there’s plenty of fuel in there.
Alfiehiron
The fuel lines are 100% not kinked and it’s the Bosch one
Bosch code - 1 582 980 141
vtl
I put this same pump into my 2005 XC70.Alfiehiron wrote: 20 Dec 2025, 14:15 The fuel lines are 100% not kinked and it’s the Bosch one
Does it look like there's a vacuum buildup in the fuel tank? Vacuum would work against fuel pump. Not sure how EVAP stuff looks in your market, maybe a solenoid is stuck or canister is clogged?
- 124 Views
Last post by Sveedy
- 2199 Views
Last post by Sommerfeldt
- 16168 Views
Last post by Richard99
- 9 Replies
- 4850 Views
Last post by matt_linegar
- 1728 Views
Last post by 98v70dad
