How are my cylinders looking?
Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
Bought a budget boroscope to check the cylinders out.
The car burns oil, especially at stop lights and long idle.
Compression is evenly across all cylinders. I don’t have a compressor to perform a leak test.
Any guesses on the pictures if a valve stem seal job is enough?
The car has 450k km currently. I drive less that 7500km a year.
1/2 a shitbox V70 1998 2.5 NA
Sveedy
Year and Model: 96 850 Turbo
Has thanked: 445 times
Been thanked: 479 times
Post by Sveedy »
Those cylinders look beautiful. New seals and you should be good to go.
1999 V70 GLT
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1078 times
Post by volvolugnut »
Yes, good cross hatch honing pattern.
Has thanked: 2211 times
Been thanked: 1852 times
Agree as well. As already mentioned, new valve stem seals are needed.
Chieber
Post by Chieber »
Thanks all!
I’ll put the valve stem seals Ann’s tools on my to buy list for the next round of repairs. Unless it doesn’t pass emission tests that’s soon to be due.
Has thanked: 1611 times
Been thanked: 4075 times
Buy the stem seals in the kit, not by the piece. Since you live in the Health Care side of the Atlantic , you can get them from Skandix.de pretty cheaply
The kit has both the seals and the little protective nipples if you choose the sadistic path of doing the stem seals with the head on
giovannibianco
Year and Model: 850 1994 v70 1998
Post by giovannibianco »
Hello,
Hey can you point me towards the model of boroscope that you bought? I'm intrigued as it seems you can "look back up to the spark plug hole that the wire has come through... Did you get it from Aliexpress?
Cheers, John.
Chieber
Post by Chieber »
giovannibianco wrote: 28 Dec 2025, 11:08 Hello,
Cheers, John.
I bought the cheapest one since I don’t use it daily. My only requirement was that it does have a articulating camera to swivel up and down.
The resolution and lighting is so-so if you compare it to what yt’ers use. But those boroscopes are like ten times more expensive.
https://a.aliexpress.com/_Ew1JzLm
wizechatmgr
Has thanked: 45 times
Been thanked: 129 times
Post by wizechatmgr »
According to AliExpress - not able to be shipped to USA for those wondering... Almost like they are tired of the tariff gotchas.
2023 Lexus RZ450e -66k
ZionXIX
Has thanked: 66 times
Been thanked: 195 times
Post by ZionXIX »
I saw this one on Amazon for $79
https://amzn.to/4jq7Wb1
