oil sump to block, anaerobic sealant, 2001 xc70
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
under the impression that the oil sump to block was sealed with the orange (i believe elring el-liq 74, correct if wrong) anaerobic sealant, however i see no appreciable sign of it, is this what one would expect it to look like after 25 years on the mated surfaces? these pictures are as yet untouched/cleaned surfaces.
i have much higher resolution images if needed, just trying to be light on site/browser resources.
thanks
Blacklab467
Year and Model: 2007 xc 70
Has thanked: 117 times
Been thanked: 271 times
Post by Blacklab467 »
That looks about right, mine looked the same. I used permatex upon reinstallation, can't recall the part number but anaerobic sealant.
2003 XC 70 (sold)
Has thanked: 1611 times
Been thanked: 4072 times
That’s what it looks like correctly dosed. Most people use way too much
https://www.amazon.com/Permatex-51813-A ... r=8-1&th=1
lrock
Post by lrock »
i have the el-liq 74, is permatex preferred?
applied with foam roller, correct?
darylrobert
Year and Model: V70 240 740t xc70
Has thanked: 6 times
Been thanked: 44 times
Post by darylrobert »
Yes, i used the Volvo stuff, only need a small bead. Used green scotchbright to clean surface and tiny foam roller for sealant. Make sure to clean out the oil pickup mesh.
XC70Rider
Year and Model: 2007 XC70
Has thanked: 36 times
Been thanked: 42 times
Post by XC70Rider »
With the sump dropped replace all the O-rings and gaskets with this kit
https://www.fcpeuro.com/products/volvo- ... r-30750783
I rolled on Permatex Anerobic Sralant 8 years ago with no issues.
lrock
Post by lrock »
XC70Rider wrote: 25 Dec 2025, 00:11 With the sump dropped replace all the O-rings and gaskets with this kit
already ordered and received
