2005 V50 - intermittent blower
Help, Advice, Owners' Discussion and DIY Tutorials devoted to the second generation C70, S40 and V50 Volvos -- awkwardly model year 2004 ½ onwards -- plus where to go for advice and discussion on Volvo's sporty C30 Coupe powered by Volvo's ubiquitous inline 5-cylinder power plant.
MilesM
Year and Model: 2003 V70 AWD
Post by MilesM »
Hello all,
I'm chasing down what seems to be an electrical gremlin related to the heater blower motor on this car: a friend originally bought the car and I did a bunch of work on it including changing the blower fan. When I bought it back from my friend, the blower fan was only working intermittently.
When I first worked on the car, the blower died and did not come back at all. I replaced it with an aftermarket blower and while it worked at first, it now seems to be only intermittent.
Any thought as to where I should start with this? Since it works sometimes, I wouldn't think fuse, but I'm not 100% about that either. Could this be a ground issue?
Any ideas?
Thanks,
Miles
Has thanked: 1850 times
Been thanked: 1712 times
Did your friend use a new or used blower motor? Also depending on brand used it could be crap out the box.
Likely you will have to strip the system down and check his work.
