Vida CEM swapping
S40cem
Year and Model: 2006 s40
Post by S40cem »
vtl wrote: 19 Dec 2025, 08:17
S40cem wrote: 19 Dec 2025, 08:05 Thank you very much for your reply.
I tried different order settings from 0 to 4, but every time the software reported that the PIN code could not be cracked. Each attempt produced a different 6-digit result.
Try to remove this line: https://github.com/vtl/volvo-cem-cracke ... .ino#L1322 (and similar line in one_pass branch, try it there, too). Also show a good picture of your hardware?
I tried deleting line 1322, but unfortunately the PIN code was not cracked.
S40cem
Post by S40cem »
repair wrote: 22 Oct 2025, 09:10
Searching for pin on P1 - 29 seconds...
I have the same CEM module number. How did you manage to do it?
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
Is it an OBD cable? CAN uses a differential signalling, the wires need to be twisted.
If you crack your CEM on the bench (outside of car) you need to terminate CAN bus - the yellow jumper on your CAN bus shield.
gavik
Year and Model: 2006 xc90
Has thanked: 21 times
Post by gavik »
dikidera wrote: 17 Dec 2025, 10:05 Please test this new version. It should have fixed the issues, but most importantly, verify when the parts catalog loads that its data is 1:1 with the real vida. What is weird in your screenshot is that the vehicle shows 5 profiles, but on my android-vida I only get 3. What region is that?
Can you post the finished APK? I can't compile it.
Dragoz001
Year and Model: Xc90 2004
Post by Dragoz001 »
Hi all,
Thanks for your great job here.
I made the sketch with a Teensy 4.0 but I'm failing to connect to the HS CAN on my MY04 XC90.
My CEM is a CEM-B, part number is 08688513 so it requires a K-Line activation. I use some transistors to send the K-Line keep alive message.
I managed to see the LS CAN but not the HS.
Any help would be greatly appreciated!
Merry Xmas to all!
Gilles
vtl
Post by vtl »
This CEM style can't be cracked via timing attack.
Dragoz001
Post by Dragoz001 »
Thanks for your fast reply!
Oh. I thought it was... This ref is listed in the code.
Any other solution?
vtl
Post by vtl »
Dragoz001 wrote: 25 Dec 2025, 09:09 Thanks for your fast reply!
Any other solution?
Arduino EEPROM reader, can find in this thread. Need to take the CEM out and solder a bunch of wires.
Dudde
Year and Model: 2005 V70 and more
Has thanked: 16 times
Been thanked: 17 times
Post by Dudde »
Any other solution?
Use OM to get pincode through OBD
Dragoz001
Post by Dragoz001 »
OM?
