Hello. I'm new to the forum and to Volvo ownership. A couple of weeks ago I picked up a 2009 C30 T5 R Design. So far I'm loving it, but like any used car, it has a few issues. I'll be buying new rear shocks and associated parts to get rid of the clunking in the rear end. I'll follow up with motor and transmission mounts.
What I could use some info on is regarding the headlights. Last weekend I wrapped the left headlight wires in electrical tape because the plastic coating on the wires is deteriorating and causing the bulbs to short out randomly. This worked for about a week. Is there a wire harness I can get to replace the old wires? These are the xenon headlights.
Also, is there a site here I can get parts diagrams and part numbers?
Thanks.
C30 Headlight Question
- Has thanked: 2857 times
- Been thanked: 1332 times
Welcome to MVS and Volvo ownership, C30ing.
VPW: https://www.volvopartswebstore.com/show ... bly=237392
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.C30ing wrote: 26 Dec 2025, 21:17 Hello. I'm new to the forum and to Volvo ownership. A couple of weeks ago I picked up a 2009 C30 T5 R Design. So far I'm loving it, but like any used car, it has a few issues. I'll be buying new rear shocks and associated parts to get rid of the clunking in the rear end. I'll follow up with motor and transmission mounts.
Thanks.
This has worked well and pretty permanent. Do not get the high temp tape as it is stiff and more electrical tape like whereas this is a felt tape with self adhesive on both sides yet not sticky with use. Excellent for interior hardness and other wiring needs.
https://www.amazon.com/XFasten-Harness- ... o1-20&th=1
Refurbishing 00 S70 SE NA headlights and wiring.
viewtopic.php?p=636664&hilit=c30+headlight#p636664
- MoVolvos
- MoVolvos
Installed the following kit from 1A.
Ford Mazda Volvo Rear Driver & Passenger Side 4 Piece Control Arm Set TRQ PSA62119
https://www.1aauto.com/ford-mazda-volvo ... 1asfk02136
viewtopic.php?p=571511&hilit=c30+headlight#p571511
On 1A's parts link above.
- MoVolvos
.C30ing wrote: 08 Jan 2026, 19:16 Thank you so much. I have the tape ordered. What did you use to secure the lens to the assembly?
We reheated the oid adhesive and clamped. We also used exterior window silicone on some areas we felt that required it.
- 733 Views
Last post by TheOEL
- 441 Views
Last post by RickHaleParker
- 357 Views
Last post by moorlander
- 424 Views
- 693 Views
Last post by MoVolvos
