Vida CEM swapping
vtl
Year and Model: 2005 XC70
Has thanked: 130 times
Been thanked: 686 times
Post by vtl »
Treur wrote: 29 Dec 2025, 10:38 If you're tired, it means you're not interested.
I'm interested in it like a shovel maker in gold rush era as it speeds up my early retirement :) Seeing internet turning into a dead space filled with generated content is pity on the other hand, and makes new topics research way more difficult. Maybe I'll need to double down on reading old good human-written books :)
vtl
Post by vtl »
Hey, I was right with "some sort of power saving mode" in P1, where sirloin's one_pass branch totally crunches it! :)
Screenshot at 2025-12-30 12-25-29.png (30.95 KiB) Viewed 522 times
The bringup to running state has a constant or constant enough run time, that's why a correct byte latency is seen with such a great precision and repeatability.
oscilloscope
Has thanked: 27 times
Been thanked: 11 times
Post by oscilloscope »
Treur wrote: 28 Dec 2025, 14:01
oscilloscope wrote: 28 Dec 2025, 11:52
Treur wrote: 26 Dec 2025, 06:28 Does anyone have DHA files for the p3 platform? I need the SCU pairing procedure.
Do you mean the synchro process?
You could certainly call it that, but it's not really synchro. It's a synchro between SCU and CEM.
I have all the small softwares which where avaliable from pretty much all of the versions avaliable to perform this procedure, some have been cracked which have some sort of virus inbedded inside they work without issue, the others require activating, there is one which is for the sid807 which apparently requires a constant connection to a server which of course doesnt exist anymore but I am unsure if that is true, as based on the other applications they work independently.
Treur
Year and Model: 2007 V70
Has thanked: 3 times
Been thanked: 7 times
Post by Treur »
oscilloscope wrote: 30 Dec 2025, 11:05
I'm happy for you
oscilloscope
Treur wrote: 30 Dec 2025, 12:22
I'm happy for you
Well i am happy to share if you want them , then maybe it might help you do want you want to find out. It wasn't a brag.
Treur
Post by Treur »
oscilloscope wrote: 30 Dec 2025, 12:25
I'm happy for you
It would be nice, maybe I can get what I need from there.
Dudde
Year and Model: 2005 V70 and more
Has thanked: 17 times
Been thanked: 17 times
Post by Dudde »
Are you talking about the codecard softwares?
duzi
Year and Model: S60
Has thanked: 18 times
Been thanked: 5 times
Post by duzi »
SCU: 8-byte synchro data via two addresses .
CEM (EEPROM) + CRC
oscilloscope
Dudde wrote: 30 Dec 2025, 13:12
No
But I know someone who does have them.
Dudde
Post by Dudde »
oscilloscope wrote: 31 Dec 2025, 02:22
No
I have most of the codecard softwares, i have some unfinished software i started making with everything in one place. But if you have any other softwares and want to share i would be happy to take a look at them
