Will try to keep this short. Daughter driving, came back, compression down to 10-20 PSI in all cylinders except #3 @ 40 PSI. No idea why it lost compression. This engine has a cam chain so not likely jumped timing. 160K miles.
Put oil in the cylinders, compression came back to 140 PSI in all cylinders. Has misfire on #1,2,4, random and primary coil B P0352. Swapped coils misfire changed to #1,2,3. No rearranging of coils gave consistent cylinder # misfire except #1&2. No unusual noises other than rough running.
Put in new iridium plugs, no change. Eventually changed all the coils, plugs (gaped to 0.028"), injectors, cleaned throttle valve, replaced MAF sensor, Now misfire on #1,2, and random along with the permanent codes misfire #1,2,3,random, P0352. Checked all the fuses, pulled and replaced. Checked signal to #1 coil on oscilloscope, consistent pulse.
When started cold, it runs at 1500 RPM with a trace of misfire but when the RPM comes down to idle it gets rough and triggers the check engine light.
Have run out of things to change or check. Any suggestions?
Thanks.
2010 XC60 3.2L Misfire
magnograil
- Year and Model: 2010 XC60 3.2L
- pgill
- Year and Model: 2010 S80, 2008 LR2
- Has thanked: 120 times
- Been thanked: 189 times
Take a look at this thread
https://www.freel2.com/forum/topic38702 ... ight=p0016
I suspect that your variable valve lift solenoid is faulty.
There are two solenoids and to get to the left one by cylinder 1 you will need to lift the engine and disconnect the engine mount most likely.
Good luck
Paul
PS Each solenoid operates 3 cylinders and you could swap the solenoid first for diagnostic purposes
Good luck
Paul
- pgill
The solenoid on the left switches the valves from low lift to high lift for cylinders 1, 2, 4
If the solenoid is stuck in the high lift position then it should lower compression when cranking
The high lift mode is only used for higher RPMs
Let us know what you find out
Paul
Paul
- pgill
For anyone that is interested here are the part numbers for the VARIABLE VALVE LIFT Solenoid
Variable Valve Lift (2 solenoids per engine)
LR025967 Land Rover
31216281 Volvo
For my money I will use the Volvo part or the Land Rover part which ever is cheaper and available. The only difference being the box that it comes in
Take care
Paul
LR025967 Land Rover
31216281 Volvo
Take care
Paul
- 1307 Views
Last post by SofiaWilkinson
- 8350 Views
Last post by Mdquine
- 1182 Views
Last post by sandyegg
- 1363 Views
Last post by Mousey
- 1269 Views
Last post by Jack2010+
