Good Afternoon Fellow Brickers,
I've run into this pretty buggy issue with my '99 V70 GLT recently and I can't quite figure it out.
About 3 months ago, I noticed that the central locking was barely functional, working only partly (I.e. 2 or 3 doors) maybe 5% of the time - it didn't bother me much so I never really gave it two thoughts. Now a month ago, the fuel door release and the hatch release have stopped working. They both stopped working immediately after pulling the hatch release (it worked, then I hit it once more a few seconds later and nothing). I hear no actuators when I press the buttons - the central locking also now works none of the time. I've already poured so many hours into forum searching, so I figured I'd finally post.
Things I've already done:
Inspected and tested fuse #6 with a different known working fuse
Removed driver kick panel to reveal the absolute mess underneath. Not even sure how to troubleshoot what's under there (what I believe to be the CEM? among other things). I see no evidence of corrosion or water damage.
Removed all rear panelling to inspect hatch wires. Cut housing at all pressure points to find them all in good shape.
Removed driver's door panel to ensure hatch / fuel door connector was properly secured.
Sort of at a loss as my symptoms don't really match any other posts - I don't think it's a temp sensor in the actuators as that usually occurs in hot weather - and I don't think that would constitute total failure of the fuel door and hatch? Plus, I of course have to have the '99 which seems to be different electronically than every other damn P80 / P2 in the surrounding years. The car has 101k on the odometer and has been dealer serviced for its entire life up until my ownership (5 months ago). Any pointers would be incredible insight, thank you so much.
Isaac
1999 Volvo V70 GLT (P80) Central Locking, Fuel Door, and Hatch Failure
- Sveedy
- Has thanked: 445 times
- Been thanked: 479 times
I had a similar issue with the door locks - it was dirty contacts in the master switch, but no problems with the fuel door or hatch release.
The only thing that comes to (my feeble) mind that they have in common, is where the wiring passes through the door/jamb.
And Welcome !
And Welcome !
1999 V70 GLT
1999 V70 GLT
- Has thanked: 2202 times
As suggested, I would check the wiring at the driver's door connector where it leaves the connector to where it enters the door. At this age I have had to repair a few for wiring failures.
Eyesiic
- Year and Model: '93 240, '99 V70 GLT
Hey thanks for the reply. Will most definitely check that next - I was able to see from underneath the driver kick panel where it enters the door jamb and it looked ok; however, I did also notice where the wires are routed through to the door and it does seem like a wear area. Will update as I move through solutions.scot850 wrote: 30 Dec 2025, 17:33 As suggested, I would check the wiring at the driver's door connector where it leaves the connector to where it enters the door. At this age I have had to repair a few for wiring failures.
Good Luck. The wires to the A-pillar inside the car are not usually an issue unless someone has been in there doing stupid stuff. It is from the A-pillar through the flying lead into the front of the door the issues happen. They can break off at the pins or anywhere to where it enters the door.
OberonXIV
- Year and Model: 1999 Volvo S70 AWD
- Been thanked: 2 times
I had this issue a few months ago, also on a 99. The wiring harness on my drivers side door was eaten through, and I had to fix a few broken connections that went into the drivers door control panel. Same symptoms as yours (Hatch release not working, intermittent central locking), but mine was causing fuse 6 to blow. I had to pull the entire wiring harness out of the door, as quite a length of it was hidden behind solid metal.
Power systems engineer in the PNW.
Eyesiic
I hate to reopen this, but I'm still struggling with this problem. I've put so much effort into this issue and am really getting frustrated. Things I've done:
* Checked wiring in door jamb (it's perfect)
* Ripped apart rear of car to look at hatch wires (again, perfect)
* Checked fuses and tested with multiple known good fuses
* Rebuilt driver's side latch to check central locking motor PTC resistor (reading 3 ohms (within spec))
Additionally, the passenger side central locking button also isn't working. I'm at a complete loss and am extremely frustrated. The car is cherry otherwise (100k miles, perfect compression, new timing and PCV, no rust). Any more guidance would be so appreciated - even just throwing up some advise on where to poke around with the multi meter. Thanks in advance.
Isaac
PS if anyone is in the Columbus OH area and would like free lunch and beer to work on this with me, let me know immediately.
Isaac
Eyesiic
Did you end up disassembling the switch and finding contacts in there or are you referring to the connection points where the wires (from clips) touch the pins on the switch? Thank you.Sveedy wrote: 30 Dec 2025, 14:59 I had a similar issue with the door locks - it was dirty contacts in the master switch, but no problems with the fuel door or hatch release.
And Welcome !
hydar123213
- Year and Model: 2000 s70
The resistors fail 100% of the time so they should probably be deleted (you can also test the motor with a power supply before putting it back in) but that doesn't match the fuel door and hatch also not working. These controls all go through the VGLA module which is under the drivers side kick panel and can store codes, you can read the them with vida or the 850 OBD app (for me vida timed out connecting to the module but 850 obd was able to communicate with it, probably bad dice connector). If the codes don't point to anything you will need to get the wiring diagrams, start at where you expect things to happen(i.e. the latch) and see if it is getting the signal, if not go further up, etc., but all of those things not working at once suggests that the VGLA module might have a code and is refusing to work because of it.
- Been thanked: 4068 times
The common theme here is the driver side master switch panel, all the juice for the latching goes through that switch .
Switch doctors makes a decent cheap replacement at about $35, new $150-200 ftom Mother Volvo
The classic failure is caused by broken tailgate wires at the upper left tailgate latch
See this thread…
viewtopic.php?t=74250&hilit=Oneonta
See this thread…
- 665 Views
Last post by TerrDawg
- 10 Replies
- 3560 Views
- 14 Replies
- 6569 Views
Last post by jmcguire
- 461 Views
Last post by Chaz
- 1229 Views
Last post by Window_Licker
