C70 front springs should fit on a v70 right?crasbe wrote: 17 Jan 2026, 10:23 I tried to reassemble the front suspension of my V70 I today, but didn't get very far. The spring hits the body?!
The car is a 1998 V70 I with the B5254FS engine. The original spring code is 32 and the springs were marked green.
The new shocks are TRW JGM278T, the springs are KYB RA3789, the upper strut mounts are SKF VKDC 35634.
The lower control arms are TRW JTC916/JTC917.
I double checked all the part numbers in VIDA and they match
As you can see, they are bowed "outwards", but the spring sits all the way in the indentations. The spring should be the right way around, the smaller winding is towards the shock and the bigger winding towards the upper spring seat. That is the way the old springs were installed and IMO the only way they fit. What's odd is that the writing on the springs is upside down this way, but that's not the first time I've seen that.
The consequence is that I can't get the upper bolt of the wheel knuckle in before the spring hits the body.
I didn't want to open a thread for this singular issue, but did anyone ever experience something like that?
Your kyb springs shows up as c70 springs.
According the specifications there’s some difference in height and outer diameter between the kyb spring you have now and the kyb spring that shows up online for a v70.
