Subframe Bushings - Think i created a major ooopsie
BlackBart
Has thanked: 927 times
Been thanked: 884 times
Re: Subframe Bushings - Think i created a major ooopsie
Post by BlackBart »
lobsterclaws wrote: 16 Jan 2026, 09:51 …However I am not sure about my subframe alignment after all…”
I may be off but I think the one corner with the pin locates the subframe. It can rotate some but not to a huge degree. The other 3 bolts lock it into place. The small error in the orientation to the chassis / body is taken out with the suspension alignment.
This is likely so the assembly process is faster at the factory.
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
Krons wrote: 16 Jan 2026, 16:26 If you do motor mounts — definitely do the OEM brands (Hutchinson) as the Off brand ones I used made the car vibrate worse after install than the 150k+ mile old ones.
Never heard of "Hutchinson", I don't think those are available in Germany. But you can get Lemförder engine mounts, although they are somewhat pricey. Also other shades of quality.
[/quote]
Per the FCPEuro.com website Hutchinson was the original equipment supplier for many of the P2 chassis cars.
08 C702.5T (sold)
The non-Swedes:
vtl
Year and Model: 2005 XC70
Has thanked: 114 times
Been thanked: 606 times
Post by vtl »
lobsterclaws wrote: 16 Jan 2026, 09:51 However I am not sure about my subframe alignment after all.
As said, you have to do a 4WD alignment after touching the subframe, front or rear. Your thrust angle has changed, need to address that.
lrock
Year and Model: 2001 v70 xc
Has thanked: 9 times
Been thanked: 37 times
Post by lrock »
lobsterclaws wrote: 16 Jan 2026, 09:51 However I am not sure about my subframe alignment after all. I followed the instructions from Vida for Torque, used new bolts and also new plastic washers. I am pretty sure that the subframe is slightly off the old witness marks at the body. Not sure if this is an issue at all, as I also got a new rear motor mount in and the engine sits about 2cm higher now.
just did this job as well, did you make sure to line the notch in the bushing up with the witness mark on the subframe?
Krons
Post by Krons »
[/quote]
08 C702.5T (sold)
The non-Swedes:
