My S80 is dead in the water. When I first tried to start it, it ran for a few seconds and then died. Now it turns over but won't start at all. I'm getting a message - "Anti-skid Temporarily Off". This is not the first time that this has happened. The last time, the dealer hauled it in and told me there was nothing wrong with it. Of course, it had started when it arrived at the dealer.
Does anyone know what the problem is?
Thanks,
Knucklehead
32,625
"Anti-skid Temporarily Off" Message 2004 S80
MadeInJapan
- Has thanked: 17 times
- Been thanked: 35 times
It means the Dstc was temporarily turned off by your car for whatever reason. I wouldn't think your no-start condition is related. However, it could be a general computer glitch...displaying the message as well as not allowing your car to start. Is your car still under warranty?
Knucklehead
- Year and Model:
Thanks for your reply. Yes; thank goodness, it's still got about 2 months left under warranty. They will pick it up in an hour. I hope they find the glitch and fix it permanently this time.
Knucklehead
Knucklehead
did you ever figure this out? If so, what was it, and was the no-start related to the message? I ask because I have a similar problem, but the message is "anti-skid service required" and the car won't stay running. If I crank again, it won't catch, but if I remove the key, it starts and won't stay running. My tech says that the memory on the CEM is being erased and thinks - ,maybe - that replacing the ABS module will do the trick, but that's a very expensive maybe. Advice?
Knucklehead
- Year and Model:
This happened again in July and the diagnosis was a bad sensor in the brake pedal. So far, so good since the sensor was replaced, but the car hasn't been driven much since then.
By July, the car was out of warranty but Volvo treated this as a warranty repair (as they should have).
Knucklehead
Knucklehead
- 2775 Views
Last post by xHeart
- 9 Replies
- 2126 Views
Last post by theWIFES_S70
- 1751 Views
Last post by nsjames
- 4986 Views
Last post by Treiku
- 689 Views
Last post by Ethan5150
