- Been thanked: 4069 times
Digging out. Have to say Eugenia, the new xc90, just blew out of 12 inches of snow and blow like it wasn’t there
- 850 LPT
- Has thanked: 335 times
- Been thanked: 247 times
Also digging out. Got Ingrid the pewter S70 out today. 3 more Volvos to go. It started snowing again today so I gave up after the first one.
58' Porsche Diesel Junior
13' Honda Odyssey
13' Honda Odyssey
You guys got pasted up in CT much worse than us, I think
Don’t forget the Porsche
- Krons
- Has thanked: 198 times
- Been thanked: 215 times
Kid called this week that the 2008 S60 is losing coolant. Bummer as that is the nicest and lowest mileage Volvo in the fleet. Hoping the negative double digit (F) temps didn’t take out the head gasket on warm up. Told him to check for external leaks…likely will send to my independent mechanic if it doesn’t heal itself with warmer weather.
Acquired a 2017 Focus last week so at least have a spare if/when it goes in the shop.
08 C702.5T (sold)
The non-Swedes:
08 C702.5T (sold)
The non-Swedes:
XC70Rider
- Year and Model: 2007 XC70
- Has thanked: 36 times
- Been thanked: 42 times
Used my P2 to drive up to Davidson County TN just south of Nashville. With 4 chainsaws and a few coolers in the back 4 of us helped do some tree cleanup the last 2 days. The southerners were biting their teeth while I safely drove over the icy roads. I am so fortunate that ice storm shifted north of me. I did notice freezing rain on Saturday afternoon but after sunset the warm gulf air came up and increased the temperature back to 40f.
- Has thanked: 2205 times
What good people you guys are. I'm sure those folk will really appreciate your kindness.
No shortage of Volunteers, indeed.scot850 wrote: 28 Jan 2026, 00:10 What good people you guys are. I'm sure those folk will really appreciate your kindness.
vtl
- Year and Model: 2005 XC70
- Has thanked: 130 times
- Been thanked: 686 times
P2 starts in 40 negative every day, winter in, winter out, without anything happening to MLS gasket.Krons wrote: 27 Jan 2026, 21:14 Kid called this week that the 2008 S60 is losing coolant. Bummer as that is the nicest and lowest mileage Volvo in the fleet. Hoping the negative double digit (F) temps didn’t take out the head gasket on warm up.
I'm with vtl on this one. I think it is unlikely the head gasket is the issue. More likely a hose is leaking and just needs nipped up due to the cold. Maybe also need to check the heater core if nothing else found.
- Has thanked: 987 times
- Been thanked: 1076 times
Coefficient of expansion of aluminum (typical thermostat material) is about 30 percent more than stainless steel (typical hose clamp material).Krons wrote: 27 Jan 2026, 21:14 Kid called this week that the 2008 S60 is losing coolant. Bummer as that is the nicest and lowest mileage Volvo in the fleet. Hoping the negative double digit (F) temps didn’t take out the head gasket on warm up. Told him to check for external leaks…likely will send to my independent mechanic if it doesn’t heal itself with warmer weather.
This might be enough for the clamp to get a little loose if temperature drops a lot.
It might only leak on startup until everything warms.
