Rusted connection on exhaust.
SCVolvo2007
Year and Model: 2007
Post by SCVolvo2007 »
Need some ideas to connect this. Can’t replace connection bolts since holes are rusted out.
2007 Volvo Xc70
Been thanked: 466 times
Post by cn90 »
Get a shop to weld it together?
Krons
Has thanked: 193 times
Been thanked: 202 times
Post by Krons »
When my kids 2002 S60 2.4t muffler rusted at the hanger I replaced with a kit like this. Came with hardware to bolt to the catalytic converter. If you have that much rust the muffler at the back may not have much life left. I’d assume you could source similar in your country.
https://ebay.us/m/gNbN6z
08 C702.5T (sold)
The non-Swedes:
MoVolvos
Has thanked: 310 times
Been thanked: 524 times
Post by MoVolvos »
SCVolvo2007 wrote: 04 Feb 2026, 10:13 Need some ideas to connect this. Can’t replace connection bolts since holes are rusted out.
2007 Volvo Xc70
Depending on your situation. Search "Exhaust Flange Repair".
DavidE7
Year and Model: 01-07 V70, S60, XC70
Has thanked: 53 times
Been thanked: 61 times
Post by DavidE7 »
I drilled out the rusted and broken studs on the exhaust flange and replaced them with stainless steel bolts, washers, and nuts from a hardware store. Tried to find a picture without any luck. Getting the drill bit to bite and stay centered is tricky. My angle grinder does a good job getting a flat surface.
David E
2001 Moondust V70 2.4 293,000 miles
2001 Nautic Blue V70 2.4 224,000 miles
2004 Nautic Blue XC70 2.5T 251,000 miles
new: 2004 Black Saphire V70R 193,000 miles
2007 Titanium S60 2.5T 275,000 miles
2007 Magic Blue S60 2.5T 233,000 miles
2007 Silver V70 2.4 200,000 miles
P2 Volvos for every person in my family
jonesg
Has thanked: 69 times
Been thanked: 479 times
Post by jonesg »
this s the style that held up for me, use dble steel gasket and high temp red rtv.
Measure the exh pipe diamter to get the right size.
Clean the mating flanges with a belt sander, apply rtv/gaskets and raise the pipes with a trolley jack on a milk crate, then cinch the bolts.
https://www.amazon.com/EVIL-ENERGY-Exha ... 9hdGY&th=1
MoVolvos
Post by MoVolvos »
If for some reason you aren't able to use the existing holes you can try this.
MoVolvos
Post by MoVolvos »
jonesg wrote: 04 Feb 2026, 21:50 this s the style that held up for me, use dble steel gasket and high temp red rtv.
Glad those worked for you. I have a clamp that I was going to use on the 08 C30 T5 2.0 M66 but the car was put on non-op due to clutch issues.
EVIL ENERGY 2.25 Inch Exhaust Clamp,2 1/4" Butt Joint Band Clamp Sleeve Coupler Stainless Steel for Pipes,Mufflers,Catalytic Converters
https://www.amazon.com/EVIL-ENERGY-Exha ... r=8-6&th=1
br0dy519
Year and Model: 2004 XC70
Has thanked: 123 times
Been thanked: 115 times
Post by br0dy519 »
I bought one of those butt-clamps but my soup can with two clamps has help up for 3 years.
04s60 2.4
04xc70 2.5t
SCVolvo2007
Thank all for quick responses. Now, who knows a guy in Columbia, SC who can help my son away at college fix this?
