noisy blower fan
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
The 07 S60 2.5T fan will squeak when the car is moving forward from a stop or coming to a stop. Bearing is sloppy but hoping it's still be okay with some lube. Can't wait for warmer weather.
vtl
Year and Model: 2005 XC70
Has thanked: 129 times
Been thanked: 686 times
Post by vtl »
MoVolvos wrote: 06 Feb 2026, 16:56 .
It is warm now in North Carolina, why are you complaining?
MoVolvos
Post by MoVolvos »
vtl wrote: 06 Feb 2026, 17:12
Cold if you lived most of your life in CA :D . Just when I start getting use to the heat or cold the season is over. I've also lost 20 lbs within perhaps 6 weeks 3 months back due to the cancer so I'm still skin and bones :shock: .
vtl
Post by vtl »
MoVolvos wrote: 06 Feb 2026, 17:48 Cold if you lived most of your life in CA :D . Just when I start getting use to the heat or cold the season is over. I've also lost 20 lbs within perhaps 6 weeks 3 months back due to the cancer so I'm still skin and bones :shock: .
Sorry to hear that, man... I send your way a virtual bread, beer and bacon.
Has thanked: 1609 times
Been thanked: 4065 times
br0dy519 wrote: 06 Feb 2026, 10:57
erikv11 wrote: 03 Feb 2026, 15:43
erikv11 wrote: 03 Feb 2026, 11:16 It is already warming up, you can forget about it until next winter! ;)
On my S60, the blower motor started whistling in the winter of 2018. I still haven't replaced it (viewtopic.php?p=643927&hilit=garage#p643927). Sound never got much worse, and it makes no noise at all in warm months. Just one data point and YMMV, but FYI.
@abscate please note a sample size of n=1
That makes a SNR OF SQRT(1) = 1
Been thanked: 504 times
Post by cn90 »
I have saved many electrical motors by lubricating the bushings. Very often, ppl call it "bearing", but it is essentially a "bushing", a cost-cutting measure in places with light load and simply spinning around. A bushing is cheaper than ball bearing:
- Portable electrical space heater...1 drop of oil every 5-7 years.
- Hair dryer motor...
- I have an old Bosch clothes dryer...same thing...1 drop of oil every 5-7 years.
- The only problem with Volvo (or any car) blower motor...
it is a contortionist position you assume to get it out of the car: it is not a pleasant job as you get older.
Once the blower motor is on a bench, it is VERY EASY to lubricate it. I showed the tricks in 2005 XC90 forum: I did it almost 10 yrs ago, so far so good.
Another benefit of lubricating the motor shaft...1 less item going to landfill site...
I managed to silicone spray lube my p2 blower which would chirp on deceleration only. Still good
Has thanked: 311 times
Been thanked: 817 times
abscate wrote: 08 Feb 2026, 08:41 I managed to silicone spray lube my p2 blower which would chirp on deceleration only. Still good
This is a great idea, give it a quick spray in situ. I might actually try it! Maybe next cabin filter change.
Post by cn90 »
Hi @abscate,
Do you have a photo to show how to spray in situ?
cn90 wrote: 08 Feb 2026, 12:31 Hi @abscate,
I searched and couldn’t find this job. Did I make this up in my head? My blower definitely was noisy and now it isn’t. Maybe I replaced it?
