Hello Forum, I have a problem in Cold wheathe Whith 99 Volvo V70, In mornig, cold wheather I start the Engine I wait to warm up. When I put it in reverse, hard noise in the transmission. I just change Trasmitio fluid do not help me with nothig I have the same problem.
Somebody knows what the Problem I will appreciate your help.
Dimitry
1999 Volvo V70 Transmission hard reverse shift
- Has thanked: 2209 times
Is the car turbo or non-turbo (NA)?
How cold is cold where you are? Cold up her is -40C/F
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
.DimBor22 wrote: 09 Feb 2026, 20:14 Hello Forum, I have a problem in Cold wheathe Whith 99 Volvo V70, In mornig, cold wheather I start the Engine I wait to warm up. When I put it in reverse, hard noise in the transmission. I just change Trasmitio fluid do not help me with nothig I have the same problem.
Dimitry
Palo Alto CA / South Bay is not really considered cold. When you say hard noise you mean it shifts hard into gear? Check for proper fluid level again.
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
DImBor22,
There are a few possibilities.
1) As stated above make sure your fluid level is correct. Check the level when the engine has reached operating temperature
2) worn transmission or engine mounts. When placing the car in reverse, if either mounts are worn or bad there will be noticeable clunk. This is due to excessive drivetrain movement or gear stress when switching directions. if the noise only occurs when shifting into reverse, this is a definitely a possibility. Look for cracked mounts, dry rot or separation at mounting points.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
- 1085 Views
Last post by PS78
- 624 Views
Last post by kanona40
- 12 Replies
- 5500 Views
Last post by alschnertz
- 1251 Views
Last post by V7025t
- 10 Replies
- 946 Views
Last post by hharrell4th
