Find you CEM p/n in the source code, change last number in array (usually 0), try to crack, repeat.gajoss wrote: 04 Feb 2026, 09:28 How do I find the correct shuffle order? Is there a way to do that?
Vida CEM swapping
vtl
- Year and Model: 2005 XC70
- Has thanked: 129 times
- Been thanked: 686 times
gajoss
- Year and Model: V50 2005
- Has thanked: 2 times
Confirm if I'm thinking correctly. Red - my CEM number. Yellow - I change the digit - I change the shuffle order of the PIN bytes.
- Volvo CEM shuffle order.jpg (41.47 KiB) Viewed 1046 times
vtl
Yes, change it to 2. Also read this: viewtopic.php?p=592875#p592875 We need to change shuffle order for 8690720.gajoss wrote: 04 Feb 2026, 10:08Confirm if I'm thinking correctly. Red - my CEM number. Yellow - I change the digit - I change the shuffle order of the PIN bytes.
Hello the forum,vtl wrote: 22 Jan 2026, 09:49I said it works on the bench. I ran it once, maybe twice on a real carRemove autodetect line, compile/upload, wait for the message, power up the CEM quickly.
Sorry for the late for upadting my posts.
I have sucessfully read the pin on the bench, I've changed the can module, maybe the old one was dead.
To resume :
On the CEM
PIN 8 15 & 16 on +12v
PIN 6 on ground (same as the ground on teensy)
PIN 33 & 48 on CAN HS
PIN 40 & 55 on CAN LS
I've booted the CEM cracker & the CEM at the same time with a stabilized power supply.
About 15-20 minutes and the PIN code appear
Great job & thanks for your help.
vtl
Congrats! Now you can crack pins for your friendsvfred748 wrote: 08 Feb 2026, 12:52 Hello the forum,
To resume :
On the CEM
About 15-20 minutes and the PIN code appear![]()
For surevtl wrote: 08 Feb 2026, 14:29Congrats! Now you can crack pins for your friendsvfred748 wrote: 08 Feb 2026, 12:52 Hello the forum,
To resume :
On the CEM
Unfortunately, I don't know any Volvo driver, but I will help anyone in need.
Greetings from France
oscilloscope
- Has thanked: 27 times
- Been thanked: 11 times
Has the CEM cracker been tried on the later delphi CEM's?
Like these one's?
Like these one's?
vtl
Is it SPA?oscilloscope wrote: 14 Feb 2026, 02:31 Has the CEM cracker been tried on the later delphi CEM's?
Like these one's?
poteroa
Hi all.
Quite massive page count on this topic..
Have a question, and maybe someone can answer directly without need to go through 430 pages
Just read the CEM on a V70, 2001 and looking for the PIN. (And IMMO code of course if it is possible to decode from there)
I used the kaev´s Arduino BDM soft, the only problem is that you can not save the read binary with that software.
https://volvo-tech.com/en/793-2/ (Used Arduino UNO for this, as it was easily available).
Going through the peoples replys, I found info that the PIN should be located in address 0x04E000 is this right?
Do not see any sense to buy expensive programmer just for getting one remote programmed to otherwise cheap car.
Anyone able to help on this?
Oh, the CEM unit is HW-PN: 9452596
Other markings: 8645697/01W075
oscilloscope
It might be yes , i tallied up the type and compared it to xprogs connnections via bdm, now at first , I saw a locksmith wiring up a xhorse programmer to the BDM connections, and i wondered if the cem cracker has been tried out on them newer cems.vtl wrote: 14 Feb 2026, 08:35Is it SPA?oscilloscope wrote: 14 Feb 2026, 02:31 Has the CEM cracker been tried on the later delphi CEM's?
Like these one's?
- 8940 Views
Last post by RickHaleParker
- 8753 Views
- 27 Replies
- 27533 Views
Last post by cn90
- 10 Replies
- 10153 Views
Last post by jonesg
- 5383 Views
