No tachometer and spedometer 1998 Volvo S70 Topic is solved
WinDVD
- Year and Model: 1998 Volvo S70 Base
- Has thanked: 27 times
- Been thanked: 9 times
If this is the case then previous owner must have swapped the cluster in from a 99, how does one tell the difference between 98 and 99 cluster? This car is certainly a 98, it has no key chip immobilizer and the vin is 98 also.
- xanthefin
- Year and Model: 1997 850
- Has thanked: 106 times
- Been thanked: 130 times
MCU and other things on board. Maybe its Frankenstein aka swapped then.WinDVD wrote: 23 Feb 2026, 15:32If this is the case then previous owner must have swapped the cluster in from a 99, how does one tell the difference between 98 and 99 cluster? This car is certainly a 98, it has no key chip immobilizer and the vin is 98 also.
Outside only by P/N i would say quickly as they so similar honestly.
WinDVD
These are part numbers on cluster, it's possible previous owner tried to swap broken cluster with this one maybe?xanthefin wrote: 23 Feb 2026, 15:41MCU and other things on board. Maybe its Frankenstein aka swapped then.WinDVD wrote: 23 Feb 2026, 15:32If this is the case then previous owner must have swapped the cluster in from a 99, how does one tell the difference between 98 and 99 cluster? This car is certainly a 98, it has no key chip immobilizer and the vin is 98 also.
9451531 and 9168144
- Has thanked: 1611 times
- Been thanked: 4075 times
All the chip dates support a 1998 build ? Isn’t 1998 v70 early CANBYS?
On edit…No CANBUS in 1998
WinDVD
The cluster says late 1998 on the cluster green plug while the car was built in late 97 according to door plate, I'm guessing this was swapped in by last ownerabscate wrote: 23 Feb 2026, 15:58 All the chip dates support a 1998 build ? Isn’t 1998 v70 early CANBYS?
Corrected above. 1998is not CANBUS
WinDVD
I've gone ahead and purchased a proper 98 cluster, hopefully will solve the woes lol. The cluster being the wrong one makes me wonder what the real mileage is on this car lol
- 753 Views
Last post by deedatc
- 1698 Views
- 1180 Views
Last post by lcc014
- 2117 Views
Last post by Ozark Lee
- 288 Views
Last post by shaker_chi
