850 2.0 t5 picking up rpms and turbo question Topic is solved
Robby850
Year and Model: 1994 850 2.0 t5
Post by Robby850 »
Hi, it's my first post here and I'm very thankful for the existence of this forum!
I have two main problems/questions. I'm currently in the process of doing a full stage 0 on a very neglected 850 that was gifted to me. I have this problem with the car always picking up 2/300 rpms when I press the clutch while driving to change gears. Can it simply be a dirty throttle body getting a little stuck when releasing it or should i look into something else?
I'll also have to replace the turbo at some point since mine is burning oil. I have the '94 2.0 t5 (b5204t) Italian version, and I believe I should have the 13g or 13t turbo and since I'd have to replace it I wanted to go for a bigger one to spend the money only once, and I was thinking about a 16t. I don't have a lot of knowledge about it but what else would I need other than the turbo itself and a tune? Also does anyone know the part number for the 16t compatible with my engine?
Thanks to everyone!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2864 times
Been thanked: 1332 times
Post by matthew1 »
Welcome to MVS, Robby850. Could be a dirty throttle body. Might be dirty injectors, vacuum lines, a host of possibilities really. You're shooting the Stage 0 parts cannon at it either way. https://www.matthewsvolvosite.com/stage ... e_vignette
Turbo and a tune, yes start there. Did 2.0s come with Mitsubishi 16G turbos? We didn't get 2.0 5-cylinders here in North America, so pardon my ignorance on this. Also I'm only aware of 16G not 16T.
Also -> Amazon link
Robby850
Post by Robby850 »
Thanks,
The 2.0 cane with a 13g. I have also misspelled 16G haha
Has thanked: 2210 times
Been thanked: 1852 times
Does it do this at rest? So with the car standing still, if you dip the clutch the engine picks up 2-300 rpms? What is the rpm's at idle without the clutch pressed?
Robby850
Post by Robby850 »
No it doesn't do that at rest, only while driving. The idle with the clutch pressed stays the same as when it's not pressed at around 8/900 rpm
I'm thinking Matthew has hit the list further up. I'd be looking at vacuum lines and intercooler pipework for loose pipe and cracked hoses. He also mentioned the throttle body to have it cleaned.
Good Luck!
misha
Has thanked: 155 times
Been thanked: 432 times
Post by misha »
Cel on?
Read the codes...all you need is a pencil and a piece of paper since '94 produce flash codes.
OBDI diagnostic ports are on passenger's side onto ecu box under the hood.
'71 144 S
'73 144 De Luxe
'78 244 DL
'78 244 DL
'79 244 GLE
'85 340 GLS
Louiseravot
Year and Model: 142
Post by Louiseravot »
A throttle body cleaning is a good place to start, but also check the idle air control valve and vacuum leaks. To my knowledge, either can cause RPM to hang between shifts. As for the turbo, a 16T will bolt up easily, but you’ll want upgraded injectors or fuel pressure adjustments to run it safely. Hope this makes sense.
