We always appreciate when members take the time to close out the issue as it is a great help for others trying to diagnose these issues.
Thanks,
Brand new battery indicating to ‘replace’ 2 days, Car goes haywire when trying to crank. 1998 C70.
- Has thanked: 2207 times
- Has thanked: 987 times
- Been thanked: 1076 times
Note to future people who find this thread: Simple check to voltage at battery while engine running will often indicate if you have a bad charging system. You need to have about 13.5- 14 volts if charging.
- Has thanked: 1611 times
- Been thanked: 4071 times
Usually this battery drain is caused by diodes in the alternator that have shorted to low ohms, the battery just runs current through them until they are dead. You can diagnose this but playing with unfused , high current stuff isn’t electrical 101 - you can start a fire and/or hurt yourself doing this
You can safely symptom diagnose by removing the hot cable from the alternator amd seeing if that stops the drain.
That means…
Charge battery
Disconnect negative terminal
Disconnect positive at alternator. Cover with heavy rag and tape
Reconnect negative
Leave overnight.
If you are battery drain stops, voila.
That means…
Charge battery
Reconnect negative
Leave overnight.
Hoser99
- Year and Model: 2000 c70
- Been thanked: 3 times
Touch with your finger - the positive battery post where it connects to the red plastic sheaved cable leading to the starter.
If its hotter than everything else around it the copper wire has gone bad where it joins the positive battery cable. This is causing high resistance and the cable will get hot. - this can also cause some oddball faults too. - when cranking the ( uses lots of power ) voltage drops so low that many of the other sensors are below their reference voltage and they main computer thinks they’ve all gone off-line at the same time. “ car goes haywire while cranking “
you can fix temporarily - remove the cable clamp at bottom of battery to create some slack. Cut a few centimetres off the end of the cable until you see bright copper coloured wire and reattach it to a new aftermarket battery post - like one from PICO.
when working properly the post wont be hot, it will be same temp as things around it after a short drive.
Good luck
Good luck
- 515 Views
Last post by MagneB
- 521 Views
Last post by xanthefin
- 1713 Views
Last post by jreed
- 1080 Views
Last post by bigtexan99
- 2498 Views
Last post by MrAl
