HELP With Brakes. Topic is solved
- Grantkat
- Year and Model: 1999 s70 GLT
- Has thanked: 59 times
- Been thanked: 54 times
follow on to that - looks like I am upgrading my scan tool.
1999 S70 GLT ~193k
2014D VIDA/DICE
2007 Jeep Wrangler Unlimited ~ 315K
2008 Lincoln MKX ~130k
2008 Toyota Sequoia ~ 252k
Powered by coffee, stripped bolts, and questionable decisions.
2014D VIDA/DICE
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I would suspect the flexible brake hoses if fluid isn't coming out in a normal manner.
On my truck the ABS isn't in the loop unless activated, so I never mess with it when bleeding brakes.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Grantkat
Interesting....
so would a valid test be: disconnect the flex line from the hard line and see if I get flow at the hardline/flex line point? assuming the flex line is the issue, i would assume that I would get a good flow of brake fluid at that point if the flex line is the issue.
Although possible, why would 3 go out at once? just coincidence via age etc?
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- ZionXIX
- Has thanked: 66 times
- Been thanked: 195 times
Yea, just pick one wheel and work your way up from the caliper to each connection until you get good flow. All flex lines are known to degrade internally and cause all sorts of issues.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Have you tried bleeding the system with the car running. This is my new way bleeding brakes after a brake job. Have car running and press down while releasing the bleeder screw. Since the pedal is already going to the floor just loosen and then press down. You have to do all 4 in order to compare flow.
Obviously, this is a 2 person job but comparing all 4 can give you some idea where the problem might be. For instance if all 4 have no flow that means it's not in any of the system / lines out of the ABS module. From reading some of the forums this is a problem many encounter so could be a manufacture defect as in our P80 ABS modules.
454cid
That's what I had to do with my truck. I was getting almost nothing out the line disconnected from the caliper, and then after removing the flex hose, it suddenly flowed.Grantkat wrote: 02 Mar 2026, 11:21 Interesting....
I hear that the flex lines can break down inside creating blockages. Maybe they've been bad for awhile but with introduced air there was enough of a cushion in the lines that the pressure was never great enough to push past blockages?Although possible, why would 3 go out at once? just coincidence via age etc?
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 987 times
- Been thanked: 1075 times
If the brake fluid is old, it can really get to be sludge. And yes, hoses go bad on the inside. I replace hoses if I do a brake flush job on 20+ year vehicles.
- Grantkat
symptom: Pedal goes to floor with car off and with car on.
OK here is an update:
The Master cylinder is good - tested
The brake booster is good - tested
bleeder screws/calipers eliminated as a potential problem
Brake lines are solid - no corrosion
Flex lines seem good - I say this because I was able to push fluid through them manually by pumping fluid through one end I got fluid flow to the other. The difference being it wasnt a sealed system under pressure.
I removed and tested the bleeder screws and removed the banjo connection at the caliper - this eliminates a plugged or bad bleeder screw and eliminates the caliper as potential issue
now here is what I have:
Rear brakes show some fluid movement when pumping brake pedal - you can build some pressure and when you release you get a squirt of fluid - I would not characterize it as a normal flow. you can also pump the brakes with the bleeder screw open and get some fluid - again nothing of a normal flow.
Front brakes zero fluid no mater how much you pump the brakes.no fluid at the screw, no fluid with the caliper banjo bolt removed, no fluid at the hard line.
I attemped to disconnect one of the input lines to the ABS pump it is a hard line directly from the master cylinder. it is in a difficult location and I decided not to tempt fate.
at this point I am thinking it has to be at the ABS pump.
I am considering upgrading my scan tool to one which will manually bleed the ABS pump. the cost of the tool itself is less than a service visit to my mechanic of choice.
1999 S70 GLT ~193k
2014D VIDA/DICE
2014D VIDA/DICE
- ZionXIX
Its pretty insane that you can get fluid to flow through the front brakes lines at all. You could have a clog in the line or yes it could still be the ABS pump. And without more information im not sure what the bleeding procedure is. That scan tool might be able to actuate the ABS to start moving fluid or at least get air out of there. Good luck.
Did this vehicle sit a long time?
I am thinking there is some trick on this chassis to release or open valves on the ABS module.
- 10 Replies
- 5767 Views
Last post by vtl
- 1271 Views
Last post by volvolugnut
- 1357 Views
Last post by CEBirnley
- 918 Views
- 814 Views
Last post by Megaromania
