C30 Timing Belt
C30ing
Year and Model: 2009 C30 T5 R Design
Has thanked: 2 times
Post by C30ing »
Think I have a timing belt issue?
kklepack
Year and Model: 2016 XC60
Has thanked: 12 times
Been thanked: 5 times
Post by kklepack »
Yes, you do. Fix it ASAP.
C30ing
Post by C30ing »
Any idea what would cause the belt to wear like this? I haven't dug into it yet.
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
C30ing wrote: 02 Mar 2026, 15:16 Any idea what would cause the belt to wear like this? I haven't dug into it yet.
That's pretty obvious damage so you need to remove the cover and look at the path of travel to see what has been rubbing against it.
MoVolvos
Post by MoVolvos »
Has thanked: 2203 times
Been thanked: 1852 times
One of your pulleys might have a bad bearing or is misaligned causing the belt to run to the back and it rubbing on something there. Don't hesitate, get it fixed ASAP.
Year and Model: 2001 V70
Has thanked: 987 times
Been thanked: 1075 times
Post by volvolugnut »
If the belt cover has been loose in position shown in photos, the edge of the cover may have rubbed the belt and frayed it.
Fix soon! If it fails completely, it will bend your valves and get very expensive.
Krons
Has thanked: 198 times
Been thanked: 215 times
Post by Krons »
I’d do the water pump, idler and tensioner while you are there changing the belt. No reason to cheap out and skip those. I even do cam seals so I don’t have to pay my Indy to do them later.
08 C702.5T (sold)
The non-Swedes:
C30ing
Post by C30ing »
Thanks guys. I had a chance to dig a bit deeper and found this. WTF! The intake came is resting on the motor mount. How could this happen. Is it a collapsed mount? It does appear to be slanted. Could the transmission mount cause this?
The car is parked on the grass. I'll have to have it towed up the driveway and into the garage and take it apart. Geez. My 1st experience with Volvo is not going well.
Oh no!
Yes, I think you have some motor mount problems.
