Greetings,
2007 v70 140K (DSTC) is off and on showing 'Brake System / Brake Assist Svce Required' messages, AND cruise control is suddenly non-functional.
Brakes are good, brake fluid full, braking is normal. No VIDA codes during this period.
Any thoughts, links about this would be valued. Ty!
Brake System Svce Required + Cruise Control Gone '07 v70
Vova585
- Year and Model: 01v70xc,2016xc70...
- Has thanked: 228 times
- Been thanked: 238 times
For lots of people it is brake pedal position sensor. Dont cheap out and get ATE brand. But best would be to check with Vida/dice cor codes. But my educated guess would be that sensor.
You will likely need a code reader that can read ABS codes, not just ECM codes
Think $50-75 tool, not the cheap ones
A single wheel sensor problem will disable ABS and Cruise , too.
- jonesg
- Year and Model: 2004 V70
- Has thanked: 73 times
- Been thanked: 532 times
Vida is saying my right front sensor signal too low. anti skid and abs flash on and off.abscate wrote: 07 Mar 2026, 10:45 You will likely need a code reader that can read ABS codes, not just ECM codes
maybe next year.
- br0dy519
- Year and Model: 2004 XC70
- Has thanked: 132 times
- Been thanked: 126 times
Easy fix this year. Change tone ring. You can do it!!jonesg wrote: 08 Mar 2026, 05:10Vida is saying my right front sensor signal too low. anti skid and abs flash on and off.abscate wrote: 07 Mar 2026, 10:45 You will likely need a code reader that can read ABS codes, not just ECM codes
maybe next year.
04s60 2.4
04xc70 2.5t
04xc70 2.5t
- 2339 Views
Last post by cork5695
- 677 Views
Last post by NHVolvoNut
- 13 Replies
- 5580 Views
Last post by mrscullini
- 4580 Views
- 17 Replies
- 6468 Views
Last post by ignatz
