Outside the US, a different octane rating is used. For my post I'm using the US numbers.
In the manual (pic below), it shows the NA is higher compression (10.5:1) and turbo is lower compression (8.5-9.0:1). I already knew that. My understanding is that a lower compression engine can use regular 87. The higher needs 91. But either Volvo wants us to use 91 or someone has trained us to think we need to use 91 on the lower compression engines. What is it that I am missing?
U.S. octane requirement question
- CIK7
- Year and Model: 2026 Sportrailer GLT
- Has thanked: 350 times
- Been thanked: 108 times
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
Compression ratio is the static ratio of chamber with piston down and piston up. When a turbo boosts, it pushes extra air into the cylinder and the effective pressure in the cylinder is higher? How much? Iβm not sure.
I run either 91 or 94 in my turbo cars and 91 in my NA cars
- Has thanked: 987 times
- Been thanked: 1075 times
When my preferred local station stopped having premium, no ethanol fuel a couple years ago, I started using the low octane fuel. No noticeable problems.
I believe the ignition controls will adjust if knock occurs with low octane fuel.
This is on 2001 V70 T5. Also 2001 Mercedes E320.
- MoVolvos
- Has thanked: 312 times
- Been thanked: 525 times
Have been using Premium ever since it came out. Still remember using Leaded fuel especially in V8βs without CAT. The smell of muscle car exhaust
Wife noticed when I tried to save money by trying 87 and she doesnβt know anything about cars. Never had a CAT, fuel, ignition or code from potential fuel related issues.
Have 100K on a set of Iridium on the 03 Odyssey at 259K and still running smooth.
- Has thanked: 2200 times
Has anyone checked their gas mileage when running regular gas? I tried it with a couple of cars that were advised to used premium gas by manufacturer's. In both cases the mileage reduced to the point where the saving made it pointless.
- CIK7
Maybe I'll try on the gray 850 if I get the white 850 as planned.scot850 wrote: 09 Mar 2026, 12:10 Has anyone checked their gas mileage when running regular gas? I tried it with a couple of cars that were advised to used premium gas by manufacturer's. In both cases the mileage reduced to the point where the saving made it pointless.
454cid
- Year and Model: 1996 850
- Has thanked: 151 times
- Been thanked: 139 times
I had to re-read that, as at first, I interpreted CAT as Caterpillar.MoVolvos wrote: 09 Mar 2026, 09:53 .
Have been using Premium ever since it came out. Still remember using Leaded fuel especially in V8βs without CAT. The smell of muscle car exhaust.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
- Has thanked: 2856 times
- Been thanked: 1332 times
Remember premium differs by US state. Here in Colorado itβs 91 octane. In lower elevations itβs 93 octane. So, another variable.
Here Premium is 91 which is at similar elevations to Denver. We also have 93 and 94 options, but they are not called premium,
Interesting. I think there are some between 91 and 100, but they're very uncommon. There are one or two places in the metro area that have 100 octane "race gas" and it's pretty darn expensive.
Here's more octane talk: https://www.matthewsvolvosite.com/volvo ... iscussion/
- 19 Replies
- 41294 Views
Last post by Jdawgvolvo
- 1926 Views
Last post by amblerman
- 1382 Views
Last post by CIK7
- 9 Replies
- 1735 Views
Last post by MadeInJapan
- 9 Replies
- 2280 Views
