Chieber
Year and Model: 1998 v70
Has thanked: 69 times
Been thanked: 49 times
Post by Chieber »
Replaced the old steering wheel with one from a c70.
The colour is a dark grey, compared to the old black one. Luckily it’s not that much of a colour difference.
Leather is still in ok condition. But scuffs here and there, but it’s not worn yet.
The thicker steering wheel feels very nice, so I’m happy with my junkyard find.
1/2 a shitbox V70 1998 2.5 NA
Chieber
Post by Chieber »
Spoke too soon.
I need an alignment. The steering wheel is off.
Had an alignment not even two months ago…
Maybe I’ll try turning the tie rods even turns and see if that works.
Has thanked: 1609 times
Been thanked: 4065 times
Rolled the S70 Karla to EWR for a ten day trip.
30 mpg , no traffic on Sunday. Stopped and fixed SIL golf on the way.
CIK7
Year and Model: 2026 Sportrailer GLT
Has thanked: 350 times
Been thanked: 108 times
Post by CIK7 »
abscate wrote: 15 Mar 2026, 10:21 Rolled the S70 Karla to EWR for a ten day trip.
Are you still in Europe?
06 Odyssey LX, silver, 127921, current
98 V GLE/SE red, 379k, 5sp, trailer in progress...
95 854 Turbo 258K, auto, sold
09 Rav4 Ltd3.5Fwd, red, 208k/213k, sold
03 Accord 2dr V6 silver, 196K/232K, 6sp, t-boned, sold
96 964 silver, 146K, diff&trans/engine self-destr, crushed 😭
MoVolvos
Has thanked: 312 times
Been thanked: 525 times
Post by MoVolvos »
Chieber wrote: 14 Mar 2026, 07:30 Spoke too soon.
Just turning the tie rods evenly may not do the trick. Regardless which way the steering is off you need to measure the Toe to see if it's Toe In or Toe Out with the steering wheel centered before deciding which Tie Rod(s) to turn. Use trash bags under the wheels for less friction and with engine running when centering the steering for measurement. Depending if it's Toe In or Toe Out and which way the steering is pointed left or right while driving you can determine which Tie Rod to adjust.
Has thanked: 2199 times
Been thanked: 1852 times
Are you sure the steering wheel is off? Check if the turn signals cancel at the same point when turning. It could be you fitted the wheel off by one or 2 teeth on the splines.
454cid
Year and Model: 1996 850
Has thanked: 151 times
Been thanked: 139 times
Post by 454cid »
Swapped the 850 so it's last in the driveway in prep for tomorrow's snow.
1996 850
2010 Ford Focus SE
2006 Cadillac CTS
1996 Mercedes C220
1999 Chevrolet K3500
1969 Buick LeSabre Custom 400
RedBrickCollector
Year and Model: 1997 850 T-5 Wagon
Has thanked: 40 times
Been thanked: 29 times
Post by RedBrickCollector »
Finally took a peek to see why my fender light isn't working after a small repaint a bit ago.
I have no idea where the wire for it is. Should it be coming from the front singal or is it from the door area?
'97 950 T-5 Wagon
'89 and '95 Daihatsu Feroza
Goupil
Year and Model: 98' V70 LPT
Has thanked: 30 times
Been thanked: 112 times
Post by Goupil »
Finally got around to swapping the C70 rear end, took way more time than it should have because I spent a long time fighting with the handbrake... New brake hoses while I was at it, before the ones on the car turned 30 !
Fitment is nicer, the wheels are a lot less tucked inside the fender
Had to take the console out to remove the handbrake cables, so I took that opportunity to remove the wood trim that was about to give up and replaced it with an already ruined one. I now have time to figure out if it's worth salvaging it, or if I should just retrim it.
Started putting the headliner back in this evening, after finding out the loud rattle appears to be from the tailgate itself...
1998 Volvo V70 B5254T M56
1994 Volvo 945 B230FT M90
1985 Volvo 240 B230E
Chieber
Post by Chieber »
RedBrickCollector wrote: 16 Mar 2026, 08:54 Finally took a peek to see why my fender light isn't working after a small repaint a bit ago.
Are you working under a canopy or are you just that hardcore, working agains elements of nature?
